Replacement headlight lens $563 ????
Old Jul 27, 2004 | 04:28 AM
69chevelle's Avatar
2000, C230 kompressor sport,
Sorry if this topic has been talked about already but the drivers side headlight lens is cracked on my 2000, c230 kompressor. The dealer wanted $563 for the assembly. Should I buy the lens listed on Ebay for $105 and put it in myself? Is it hard to install? tia
Old Jul 27, 2004 | 10:08 AM
trbo2nr's Avatar
2004 C32, 2006 Honda CBR1000RR, 2007 Harley NightRod, 2013 Harley Road Glide Custom
I would. For me, the dealer is the last way to go. $560+ is sick.
Old Jul 27, 2004 | 03:48 PM
DougandhisC280's Avatar
2008 SLK-280
Get the European ones from www.bekkers.com . They are glass and clearer than the crappy one's our cars came with. I have them and they look much better. I think you can get the pair for less than two hundred dollars. Installation takes about an hour. 30 minutes if you don't have headlamp washers.
Old Jul 30, 2004 | 04:34 PM
jimmyzgarage's Avatar
you should be able to just buy the lens only for about 40 bucks from the dealer. Not very hard to replace either.
Old Jul 30, 2004 | 10:34 PM
EuroWerkZz's Avatar
99 M3 Forsale, 98 E320
I got mine for 154.00 for each side OEM
Old Jul 31, 2004 | 06:07 AM
Ashkan's C43's Avatar
c43
bekkers xens are not dot, not sure if that means anything anymore, if you can really get in trouble with them, unless someone knows any better, I hope its along the lines of not having a license plate on the front of your car or those neon lights under the car
Old Jul 31, 2004 | 04:05 PM
Joeyc220's Avatar
I got mine a Virtualjunkyard.us.....for $120, one part was cracked otherwise ok... took like 2-3 weeks to get it.
