POWER DOOR LOCKS WORK WHEN THEY WANT TO
If I park the car and push the remote outside of the car. They lock very slow. How do I trouble shoot this.
Search the w202 forums for vacuum pump, door locks, etc and you will find some really good info including folks that have done mods to the pump to help reduce heat and even folks that have completely taken apart the pump/valve body and repaired internal leaks in the plastic (a lot of work). The sad news is if you don't have the ability or time to do the work yourself - it can get very expensive.
Attached is from the EPC showing a general layout of the vacuum system. The distributor block (68) is built into the pump after 1997.
But there is one thing you can try. In the trunk, disconnect the negative battery and keep it off for 30 mins, and then reconnect it.This will give the CPU's a good old fashion reboot - maybe you will get lucky.
I took a air hose and blew the dust off it. It has worked since. Could be a slow leak or a glitch in the pump. Who knows.
Thanks again for your reply! We see if it last.
Attached photo of vehicle.
W202 Mercedes C200 Elegance
