Not starting need help
Old Feb 27, 2020 | 07:10 PM
BigPowerBenz's Avatar
W202 C200 and C250
Hi guys, been having a problem with my Merc c200, looked up a few things that seem similar but arent the cases for me.
the car wont start or crank or anything, I can insert the key, turn the steering wheel and all the light on dash work etc, when I turn the key to start it just turns and nothing happens.
Any ideas or suggestions?
Old Feb 28, 2020 | 11:49 AM
khomer2's Avatar
02w163ML500 / 97w210E50AMG / 99w202C230k / 95w124500e-wip
No crank - any cluster displays lighting up?
Battery? charge appropriately?
Any power to the windows or radio?
https://mbworld.org/forums/c-class-w...-turn-key.html
Old Feb 28, 2020 | 12:16 PM
W202 C200 and C250
I have my cluster lights, battery is okay put in a fresh charged one no different, windows work..passenger one kinda laggy and get stuck sometimes but think more to do with rail n motor.
car is c200 year 99.
Old Feb 28, 2020 | 12:22 PM
khomer2's Avatar
You said you're getting no crank so have you tested the starter?
When you turn the ignition key, can you hear any click? (starter relay)
Old Feb 28, 2020 | 12:25 PM
W202 C200 and C250
Theres no sounds, I think I tested relay, not sure since couldn't find an exact diagram to see which is which
Old Mar 8, 2020 | 07:58 AM
Pitayadi Wibawa's Avatar
W202 C200 Elegance AT Carlsson 1996 // R172 SLK250 AMG AT 2015
Did you try to scan it? It could be multiple possibility.
