cd changer question
Old Aug 4, 2004 | 10:11 PM
EVOnation's Avatar
cd changer question
my c280 sport came without a cd changer, but recently i bought one on ebay.
when I started looking for cables in the trunk i found nothing
me and my father in law pulled everything from the trunk but the cables are not there. Anybody know im doing wrong?? are there suposed to be cables there or not?
thanks in advance guys
pete
Old Aug 4, 2004 | 11:22 PM
torrick's Avatar
97 C280
If you remove the carpets in the trunk, the flat one then the passenger side trim, you should see a bunch of wires. The ones you are looking for are bundled as a cable, with a male plug at the end. The latter plugs right into the deck.
Good luck
Old Aug 4, 2004 | 11:27 PM
EVOnation's Avatar
hi torric
is it possible mine came without these cables?
i removed all carpeting even pulled the side covers out of the trunk, nothing there. I know what the cable looks like since i have another 97 benz with a cd changer.
Old Aug 6, 2004 | 03:42 PM
otis3's Avatar
99 C230k
For me the hardest part of installing my changer was finding the cable. I knew where to look and what it looked like but it was buried pretty good.
Orange cable with a green cap on the plug and a small black cable bundled with it. I had to remove the whole inner trim panel on that side.
Old Aug 8, 2004 | 05:35 AM
torrick's Avatar
97 C280
Originally Posted by EVOnation
hi torric
I'd be surprised if that were so
I'd keep looking...
GL
Old Aug 8, 2004 | 05:57 PM
trbo2nr's Avatar
2004 C32, 2006 Honda CBR1000RR, 2007 Harley NightRod, 2013 Harley Road Glide Custom
Should be where the battery is (to the right of it). Also, I found out before the
changer was picked up by the head unit, I had to pop radio fuse; reconnect;
enter radio code; and it worked. Took me days to figure this out. Hope it helps someone else.
Old Aug 10, 2004 | 03:22 PM
69chevelle's Avatar
2000, C230 kompressor sport,
Thanks for that info....The radio fuse...is it near the head unit?
Old Aug 10, 2004 | 03:38 PM
trbo2nr's Avatar
Not really sure. I popped the negative off the battery (did the same thing but
another member flamed me for doing it that way).
Old Sep 7, 2004 | 02:48 AM
pcolvin's Avatar
2000 C280
cd changer cable
If you have a pre-2001 car the orange fibre cable is glued up behind the carpeting to the right of the battery. You will not see it in the cable bundle right off. It will look as if it is running back to the head.
Old Sep 10, 2004 | 09:10 AM
PRHeloPilot's Avatar
................ Bell Helicopter & '05 C230 SS
my c280 sport came without a cd changer, but recently i bought one on ebay. pete
Can I ask how much did it cost you ? I'm picking up my '05 C230 today and don't need the CD changer because I know I never use the one in my other cars. I'm thinking about selling it so I want to know ballpark what it's worth.
Thanks,
Carlos
Old Sep 10, 2004 | 12:19 PM
Anaheim_Drew's Avatar
2001 C320ss, 2005 Ford F150 Supercrew, GSXR,
Thanks,
Carlos
$250
Old Sep 10, 2004 | 05:31 PM
Originally Posted by Anaheim_Drew
$250
Thanks !
