Where is the Jack Point?
Old Aug 11, 2004 | 04:49 PM
ricerokets4life's Avatar
I'm trying to drain the oil but i was unable to locate the jack point in the front underside of the car. is there some other way to lift my car up so i can access the drain bolt?
Old Aug 11, 2004 | 06:29 PM
scorchie's Avatar
GL320CDI / C63 Edition 507 Coupe (EDP) / E63 S (on order) / G500 / Smart Brabus
It might just be easier to spend $30 on a topsider...
-s-
Old Aug 11, 2004 | 06:31 PM
otis3's Avatar
99 C230k
I use ramps.
Old Aug 11, 2004 | 06:51 PM
scorchie's Avatar
Originally Posted by otis3
I use ramps.
You must have a car that is not lowered, or tires that aren't wide, or both!
-s-
Old Aug 11, 2004 | 09:17 PM
KWiK's Avatar
2002 C230 : 2007 C230
ramps???? suck the oil out....much less hassle
Old Aug 11, 2004 | 11:25 PM
do they sell topsiders at pep boys? they seem kinda expensive...
Old Aug 11, 2004 | 11:52 PM
scorchie's Avatar
If you think $30 is expensive... then I guess you should keep trying to jack the car up.
-s-
Old Aug 12, 2004 | 12:02 AM
KWiK's Avatar
I have both the topsider & the MityVac, the MityVac works much faster with a lot fewer pumps. It's well worth the money.
Old Aug 12, 2004 | 09:53 AM
torrick's Avatar
97 C280
The jacking "tubes" for the front are aft the front wheel wells, beneath the front doors. These, have to be used with the jack supplied with the car. You remove the plastic cover to access the "tube". To work under the car, you need to put it on jack stands though.
The jacking "points" for floor jacks and jack stands, are right beneath the tubes, padded with thick round rubber pieces. The problem, you see, is that the spot where you want to put the jack is also the spot you need to put the jack stands. A solution coud be to use the front engine cross-member to lift the car prior to securing it with jack stands.
However, all that said, the oil drain plug is easily accessible without lifting the car, unless it's been lowered.
Old Aug 12, 2004 | 11:58 AM
yeh that cross-member thing was the only thing i saw but it looked pretty fragile to be supporting all that weight.
Old Aug 14, 2004 | 02:30 PM
otis3's Avatar
99 C230k
-s-
Yep! Stock height, with 205s. Still have to jam the ramps under the air dam though it`s a tight fit. What I like is it gives me a chance to check under the car to see if things are OK down there. I can also hide from wife and kid for hours WOO HOO!!!!
Old Aug 14, 2004 | 02:40 PM
scorchie's Avatar
That's a good point. Not enough people look under their cars to see what it's like down there.
-s-
Old Aug 15, 2004 | 04:58 PM
henry47's Avatar
asdf
well personally i dont like the top slider as i would not know if i got everything out. i know scorchie here will have a mouthful to say to me, but by unbolting the drain, at least i know i got everything out. i've tried the top slider and i just plain dont like it. sometimes i dont even know if the hose is fully inside the oil pan. the jack points on the car should be under the side skirts on both sides.
Old Aug 15, 2004 | 07:36 PM
tpliquid's Avatar
too poor now
been using topslider since 95 still working good. better than opening the drain plug. and gettign dirty.
Old Aug 15, 2004 | 08:32 PM
henry47's Avatar
asdf
i'd have to disagree. it's easier to drain from plug for me
Old Aug 15, 2004 | 10:26 PM
tpliquid's Avatar
too poor now
STFU I"LL KELL U
Old Aug 16, 2004 | 01:29 AM
henry47's Avatar
asdf
STFU I"LL KELL U
i will beat your mom
Old Aug 16, 2004 | 02:11 PM
scorchie's Avatar
Unbolting the drain doesn't get everything out, so you don't KNOW you got everything out. There's not really much you can do to get everything out without dismantling the engine.
That's why you put new oil in, it dilutes the old stuff that's left behind.
Also, why are you so worried about getting the old oil out? It was in your engine for 3000 miles before, is it there something that makes it unbearable to be in your engine once it hits 3000? And this is how you show your respect? I hope J knows that when she hits 3000, she's outta there.
-s-
Old Oct 8, 2004 | 08:57 AM
tonewheel's Avatar
The only ramps to go with for low profile bodies are Rhino Ramps. Get them at any decent auto parts store. The have a long, gradual, wide incline and work perfectly on both my 04.5 SS Sedan and the wife's Cooper.
