1997 c280 gray hose?
Drivers side. Where it is disconnected. From somewhere?
I may have vacuum leaks I'm not sure. Most of the time the car will just turn over and not even try to start. Occasionally it will start right when you turn the key and run like a brand new car, until it gets warm. Then it starts to misfire and will eventually stall out. Getting codes for misfire on cylinder 1 and 3 and also p0300 (multiple cylinder misfire). No other codes.
