Check Engine Light at 100K miles?
Old Aug 24, 2004 | 12:56 PM
funky102's Avatar
2000 CLK 320
I did a search on this forum and didn't come up with anything so I thought I'd post the question.
Does the 'Check Engine' light come on automatically at 100K miles? Do the people here that have over 100K miles on their W202s have had that light come at that mileage?
Also, what are the usual/recommended maintenance features that should be done to the car at 100K miles? Thanks...
Old Aug 24, 2004 | 01:41 PM
karamazov's Avatar
I have a '99 C230K with 103K miles.... no check engine light yet.
Old Aug 24, 2004 | 02:19 PM
RocketR's Avatar
You can start by doing the 90K service... Goto Autozone and have your car hooked to a OBDII reader and see what the code is... probally O2 sensor.
Old Aug 24, 2004 | 02:24 PM
Hal H's Avatar
2001 CLK320
Probably cause is
...the O2 sensors.
I'd have the car scanned to see what codes are present. The OBD-II cars that use heated O2 sensors have a service life of 100K miles for the sensor.
If the heater element dies, or the sensor response gets too sluggish it will make the CEL turn on.
On the 4 cyl engines, there is a pre- and post cat sensor.
Old Aug 24, 2004 | 03:17 PM
pointman's Avatar
a car that can't do the throttle reset.
no it does not come automatically at 100k. go to mbusa.com... it gives service recommends.
Old Aug 24, 2004 | 03:46 PM
simplexchange's Avatar
My CEL has ben on for a year now... '94 C280, no problems...
Old Aug 24, 2004 | 07:58 PM
pointman's Avatar
good luck with inspection.
Old Aug 26, 2004 | 01:04 PM
What's inspection?
Old Aug 26, 2004 | 01:40 PM
pointman's Avatar
What's inspection?
