Oil change reset light!!!
Old Oct 3, 2004 | 11:55 PM
MBdismantler's Avatar
99 C230 Kompressor
I just did an oil change myself and I wanted to reset the light. My car didnt come with an owners manual. But I was reading a thread and someone mentioned I try that but it dosent work.
Close the door
put the key on the second position
hold the service button 0 for 15 seconds.
Old Oct 5, 2004 | 09:43 PM
meanie's Avatar
Here is how it really works:
1. Turn ignition switch to # 2 ( run ) position.
2. Immediately press the odometer re-set switch twice within 1 second.
3. Turn ignition switch back to # 1 ( just key in ) position.
4. Press & Hold odometer button & turn key to # 2 position.
5. Hold for 10 seconds.
6. Your new service interval should now be displayed.
7. Release odometer button.
You're done.
Old Oct 6, 2004 | 05:52 PM
99 C230 Kompressor
Hey man thanks
Old Oct 7, 2004 | 04:50 PM
meanie's Avatar
Wink
Originally Posted by MBdismantler
Hey man thanks
Did it work for you ?
Old Nov 20, 2017 | 01:46 AM
cgshawaii's Avatar
1998 C280
In my case, after following the instructions in the factory operator's manual at least five times with no result, I followed the above instructions WITH THE DRIVER'S SEAT BELT FASTENED and it worked - reset to 10,000 miles. There were two differences (some of this may just be happenstance or superstition). The above instructions say to hit the 0 button twice in one second while the factory manual says twice in four seconds, and I had the driver's seat belt fastened.
On a premium segment vehicle it shouldn't be this difficult. But I come from BMW-land, and there are plenty of "it's just that way" things there too. Hans and Fritz must think differently than... just about anyone else.
