W202 errors
Old Feb 7, 2023 | 09:19 AM
spriditislv's Avatar
c class w202
W202 errors
Hello. Im coming there with hope to get some info.
I got 1996 c class w202 with 2.0 kompressor 132kw
problem is that i got light up all things about breaking system - abs/ets/ handbreak/breakcaliper wear/ not working speedo.
cant read any failure codes from my 36pin reader. It only see instrument panel and thats it.
sometimes all mistakes disapear and all works like it needs to. But that happens only simetimes. All fuse are good. Abs sensors new, abs pump/module changed.
Old Feb 7, 2023 | 09:21 AM
c class w202
There is vin code if that helps - WDB2020251F432273
Old May 15, 2023 | 11:43 AM
Laubscherc's Avatar
W202 C200 1998, W123 200 1982, W123 230E 1982
Difficult without codes, but my money is on the steering angle sensor.
Old Apr 20, 2024 | 03:40 AM
wael badran's Avatar
W202
Same errors
I have the same problem in my w202 . Nobody knows how to solve it. Did you repair or at least know what is the problem?
