Need Help Front Flex Disk/Oils Sensor
Old Nov 10, 2004 | 01:07 PM
amgc230k's Avatar
Can someone please help me to locate where the front flex disk is (how to replace it) and how to change the Oil level sensor. Is this an easy job to do or should I take it to the dealer to have it done......By the way I have a 99 C230K
Old Nov 10, 2004 | 10:39 PM
SLAMMED_C's Avatar
1999 C230 Kompressor, 2002 E320 4matic
I believe the oil level sensor is located behind the oil pan.. the front hardy disc is located on the back of the trans in between the trans output shaft and the driveshaft.. acts as a dampener between them.
In order to replace these yourself you will need a hoist to make things much easier.. it may be something you want to have done at the dealer or a reputable indie shop.
