Check Engine
Old Nov 27, 2004 | 03:19 AM
GAMMA's Avatar
Check Engine
Just bought a 99 c230 k wit about 140000km it was running fine then check enigne light comes on, i go to bring it to dealer they want $250 to tell me whats wrong so i wanted to know if there is some way to find out wit a obd to read my codes. I went to a couple of shops they say that i have to go to dealer which i think is bs.
I changed plugs and oil no change,
I do notice these problems wit the car:
1. On cold start the engine begins to over rev, enough to shake the car then it goes away after 5 sec.
2. Upon accellerating the enigne cuts fuel or shutters around 3500rpm same on the highway basically i cant go over a 140km/h eww.
3. I also tried resting by taking of the battery no change check engine comes back on within 24 hours.
I live in Toronto plz reply wit ne suggestion's thnx
Old Nov 27, 2004 | 05:16 AM
trbo2nr's Avatar
2004 C32, 2006 Honda CBR1000RR, 2007 Harley NightRod, 2013 Harley Road Glide Custom
Could it be the mass airflow sensor?
Gamma-
Go to a local car parts store and invest in an OBD2 scan tool. The cheap ones run $99 and connects to your cars OBD2 port down below the steering column on the right. If it is the MAF sensor, you're looking at a $350-$380 part (new from one of the site's sponsors). Or, see about finding one from a salvage yard (but no guarantees). If not the MAF, it could be another sensor (again invest in the OBD2 as you'll use it over and over).
Good luck.
Old Nov 27, 2004 | 06:55 AM
electric blue's Avatar
Computer Check
At our shop we charge the customer $35.00 to plug in the computer. If they decide to have the work done and are willing to leave the car then it's a free charge. Granted some independent shops are not going to have the software to check all cars they should however cover 80% of all cars out there. Most of the time i think dealers over charge. Like going to a concert an having to spend $5.00 for a coke.
I do agree with the last poster........You could very well have a bad Mass Airflow Meter.
Old Nov 27, 2004 | 12:08 PM
GAMMA's Avatar
Thnx for the advice does the obd2 tell u exactly what the problem is or does it generate a code and if it does say codes, is there a list i can get?
Old Nov 27, 2004 | 04:11 PM
trbo2nr's Avatar
The cheap ones show a code and you simply look it up in the booklet that comes with the unit. I bought the AutoEnginuity ScanTool for $159 and use it
on my Palm Pilot. I just keep the Palm Pilot and the cable in the car. This tool
is more advanced plus you can record logs and analyze data on the desktop. I
found mine on ebay.
Old Nov 28, 2004 | 04:14 PM
GAMMA's Avatar
thnx im going to check ebay
Old Nov 28, 2004 | 04:46 PM
13benz's Avatar
98 C-230
i would check for vacum leaks first, but it sounds like a mass airflow sensor to me too, that seems to be realy common on these cars, and this subject comes up a lot. i had to replace mine at about 80,000. it may be worth a shot to try and clean the old one out with throttle body cleaner that says no residue, i have never tried this myself, i heard about it here on the boards. whatever you end up doing, dirty air filters are a mass airflow sensors mortal enemy. i don't know if the 250 is canada money or not, but my dealer charged about 400 for the part and labor, a scan tool is a great investment, and will tell you what's wrong with all cars that have obd2 hookups.
Old Nov 30, 2004 | 12:16 PM
eddieo45's Avatar
me: 2015 SL400 & 2015 ML400; wife: 2022 GLC Coupe; daughter: 2017 GLC SUV
here in the US, Autozone will scan your car for free and give you the codes. classic MAF codes are:
P0170 fuel trim malfunction- Bank 1
P0173 fuel trim malfunction- Bank 2
dirty air filter will foul MAF. Search forums for CEL or MAF; most common w202 question, I believe.
Old Dec 4, 2004 | 12:54 AM
GAMMA's Avatar
CEL codes from obdII
1. P1509
2. P0113
3. P0118
4. P1298 pending
SOUND LIKE TROUBLE what do they mean and can i fix them without dealer?
Old Jan 10, 2005 | 06:43 PM
GAMMA's Avatar
Red face Codes
i got the obd2 code reader the inova3100 question can i rest the codes from the car computer with it? if not how can I because i was told that i should rest the codes and see which codes come up 1st.
thnx!
Old Jan 10, 2005 | 07:41 PM
meanie's Avatar
thnx!
Yes you can. Use the appropriate button.
When you read the codes, it shows the order in which they occured.
Better read your manual that came with the 3100.
Old Jan 11, 2005 | 06:57 PM
GAMMA's Avatar
not working
i did what the instructions said to do i truned on the key to the on position not start and let it read for 15 sec then the codes come up once i push the scroll button then i hit erase and all it say is ErPr i dont know what that means. I went to were i got it from and they say it wont work wit 99 benz c230k i think he bs ne wayz ne suggestions?
Old Jan 11, 2005 | 07:16 PM
meanie's Avatar
page 4-7
To erase codes. Assuming you're linked & the key is on!
1. Press & release ERASE button.
The LCD display will ask you " SURE ".
2. Press & HOLD the ERASE button, until it shows DONE.
Old Jan 11, 2005 | 07:43 PM
GAMMA's Avatar
even when I press the link button it say's ErPr but the flashing car comes up on the mid left side of the screen then i press the erase button the ErPr comes up and i hold it for more than 60 sec, it still does noting by the way the only way i get to see the codes is by hitting the small button in the middle im assume it's the rest button man this frustrating.
this is what im doing i trun the ket until all the light come on the vdo srs etc..
is light up then i trun on the obd. then i hit link for a sec it say ErPr, then i hit the erase button and hold it and ErPr comes up again flashing wit two waring beeps and notin happens after that.
Old Jan 11, 2005 | 09:02 PM
meanie's Avatar
Sounds like you don't have the connector pushed in far enough, under the dashboard?
You should not get an ERROR message, if the connector is all the way in.
Old Jan 12, 2005 | 01:08 AM
GAMMA's Avatar
i will try again but if the connector is not all the way in how am i getting codes?
also my connector 7pins in it is that the right connector?
Old Jan 12, 2005 | 10:24 AM
meanie's Avatar
Yes, 7 pins is correct.
Old Jan 12, 2005 | 10:26 AM
meanie's Avatar
If the connector is not all the way in, you could be reading the codes that are stored in the 3100 from before, because you did not erase them.
Old Jan 12, 2005 | 04:27 PM
GAMMA's Avatar
I will try again making sure the cable is all the way in, one more question is there a away to clear the codes from the obd2 reader itself without it being hooked up to the car? because again when i hit the erase button it say ErPr.
Old Jan 12, 2005 | 04:48 PM
meanie's Avatar
Just plug it into the car, solid.
Turn the key to position 2 ( just before " start ".
Push " Link ".
After a few seconds you should get the codes.
Then push " Erase ".
It will ask you " Sure ".
Hit & hold the " Erase " button again.
After the codes are cleared it will say " Done ".
Old Jan 13, 2005 | 02:20 AM
GAMMA's Avatar
i think my reader is defective because i tested another car today and got the same results ErPr. Will the obd get damaged if the car is running wit it connected?
Old Jan 13, 2005 | 11:30 AM
meanie's Avatar
No.
Did you bent any pins trying to insert it into the car connector?
Old Jan 13, 2005 | 05:45 PM
GAMMA's Avatar
no none are bent. maybe i have unscrew the the connection on the car to get it in better?
