1999 w202 m111, 722.6 Dilemma
Old Dec 5, 2024 | 08:24 AM
MarkSA's Avatar
W202 1999 C240 Sport, W203 2002 c200
I am really starting to lose all hope of being able to save my old w202 1999 c240 V6.
I'm from South Africa and definitely not a mechanical genius, I spoke to a mechanic about rebuilding the engine (it smokes, really bad).This is financially not an option. I have found a few donor engines that are cheaper.
Please can you guys weigh in on engine swaps, (best candidate suggestions) from the simplest for example take m111 engine out, put in donor m111.9, m113 or 2jz engine in and run, all with a 722.6 gearbox, without ecu issues or other modules or electronics mating issues.
Or other possible solutions that have been done successfully, with examples or easy and simple problem/solution instructions or video links or blogs that I can turn too.
Help me save this classic, Thanks, all input will be greatly appreciated.
Old Dec 9, 2024 | 07:14 AM
MarkSA's Avatar
Vin ADB2020266F905192
Originally Posted by Plutoe
because of the electronics and drive train potential mismatch your best trouble free option is the same engine with less mileage---to know the exact swap provide your VIN
Here is the VIN ADB2020266F905192
I tried editing my previous msg because I had the engine number wrong, its actually 112
