Power loss after installing new battery
Anyone have any ideas? I could disconnect the battery, then reconnect, but should the engine be cold or warm when I do this? I'm guessing a throttle position sensor or something is sticking, and the computer isn't sensing the correct position upon startup.
When MB installed the new battery, the car was cold (65 degrees F) for about a week.
Any ideas?
Thanks, any advice is much appreciated.... Paul
reset and the car basically needs to learn these settings again? If so, I would
think it should be back to normal within a few hundred miles.
Could be a simple grounding issue.
If the battery terminals were coroded from the old battery, and not cleaned before the new one was installed, you could have this problem.
If the ground is not good on a 12v negative system, your sensors don't report to the computer correctly, as the computer uses the ground as it's base line voltage.
May need to replace the cables.
Cheeper than buying new sensors.
In regards to the battery cables, I think it's a good troubleshooting step. Maybe my car would have reprogrammed itself much sooner? Since it's driving great, I would rather not risk the chance of disturbing the current setup, so I won't try, but wish I had earlier in the process.
Thanks! .... Paul
