2000 C280 ( W202) Engine stopped running
Old Nov 2, 2025 | 01:50 AM
MyW203@187000's Avatar
2000 C280 W202 w/ 112 engine
I have to share this bit of info and I hope it helps other that still drive these beautiful 202's. The other day I started my car to let it warm up a bit before heading to work, as I walked indoors I noticed it had stopped running. I tried to start it again with no success, engine would crank with no codes or check engine light. Evidently this model uses fuse F6 ( 15A) in the front fuse panel with the diagnostic port in it. This circuit runs the ECU and the Purge valve also located on the drivers side engine bay with a two pin connector. I unplugged the purge valve and replaced the fuse with a 15A fuse and it started right up and did not stall. Great right, when I plug the purge valve in the engine died in a few seconds. The culprit was the damn purge valve. Hope this helps.
