MB 1998 c230 will not start
Old Apr 4, 2026 | 08:01 PM
Anthony Julien's Avatar
1998 C230
Exclamation MB 1998 c230 will not start
I changed , ignition, bypass security lock, key and K40, new starter, 15 feet wire from batter to starter added 4 grounds new start wire and ran every imaginable test the fuel pump works and it just click when you turn the ignition starter will not turn engine e when bypass the relay it turn over but no stat so i used starter fiuld to do so it works . so for some reason its not reading the fuel pump so i changed the k40 relay module. I sent it to sync the els, eis, and key . still same problem. Any ideas if i could get a set with ecu, key and ignition i will get it today for 1998 c230
