Does anyone know what OBD II code P1700 means???
Originally Posted by DougandhisC280
and most importantly....which one of us is right?
Just type in p1700, and look at " Mercedes ".
http://www.iequus.com/obd_def.asp
1995 C280
thanks for everyone's input. i just wanted to make sure the problem was the same from the last time i went to the dealership. they said it was the upshift delay valve. he said no biggie, but i need it fixed before i get a smog. supposedly this thingy keeps in gear longer when the car is still cold to help it warm up.
1995 C280
called the dealership and not too bad. $169 for the part and one hour of labor. so if i use up the gas from my loaner, we can call it even.
i have the same code and upshift delay switchover valve problem p1700
about to take my car to the stealership to fix control arm bushing and check out the tcu/tcm could i fix this myself or will i have to pay them?
1996 C36
If it is the valve at fault the repair isn't too bad. In my case it is the cable itself so the repair will be pushing $1K. Needless to say I'm not fixing it. I "trick" the computer on every startup by starting off "spiritedly" each morning so the rpms go above 3K rpm for the first shift. It helps that I have to go up a hill each day but in anycase it keeps the CE light off.
