little help please
Old Feb 14, 2005 | 12:09 PM
RobbyGT's Avatar
1998 C280 Sport
little help please
How do you pop off the "overhead console" piece that contains the dome lights and sunroof switch. I don't want to pry on it and break it. Is there a simple way to pop the whole thing off? I have to change my sample blower motor, which is located up in there. Thanks in advance.
Old Feb 15, 2005 | 10:49 PM
benzdude280's Avatar
C280
I believe you just try to get your fingernails under the edges and simply yank on it. Someone correct me if I'm wrong.
Old Feb 15, 2005 | 10:53 PM
RobbyGT's Avatar
1998 C280 Sport
Thanks. That's pretty much how I figured it out. Didn't break it either! lol. Thanks for the response.
Old Feb 16, 2005 | 12:00 AM
C280
Excellent, that's the most important thing: Not breaking it in the process of fixing it. Glad all went well.
Cheers!
Old Feb 16, 2005 | 12:24 PM
cil254's Avatar
C220
Robby,
I'm assuming you replaced the sampler blower motor ? Was it just an "easy remove and replace" type of job, or is there more to it ?
What was wrong with it, or rather what symptoms did you have ?
Thanks.
Old Feb 16, 2005 | 05:22 PM
RobbyGT's Avatar
1998 C280 Sport
Hello. My symptoms were a constant buzzing noise up in the "roof console" (the thing with the dome lights and sunroof switch). I merely pulled down from the sides of the console and pulled it down. The sample blower motor is only a couple of inches long and has a plug going to it. It pulls out, then you just unplug it and pop the new one in. Now there is no extremely annoying buzzing noise anymore! I bought the part for only $80 (with free shipping) at this site.... http://www.discountmbparts.com
Old Feb 17, 2005 | 09:42 AM
cil254's Avatar
C220
Thanks. I had the buzzing noise once, I lightly punched the console and the noise went away. No noise since then.
Old Mar 3, 2006 | 09:28 PM
FVL6's Avatar
Hello RobbyGT,
I have the same problem with my car, but I can't pull down the sunroof console. Can you please tell me the trick of it?
Thanks.
Old Mar 3, 2006 | 09:36 PM
RobbyGT's Avatar
1998 C280 Sport
Wow! That thread is over a year old! Good find! As for pulling that piece down, I remember I was a little afraid to pull on it too hard, in fear of breaking it, but once I got a little aggressive with it and shimmied it and pulled down with a little force, it came off. Just try to grab it with almost every finger from both sides of it and pull straight down, while shimmying it a little and you should do just fine. Good luck!
