Spacers????
Old Jun 10, 2002 | 01:08 AM
silentrage's Avatar
c230 coupe
Spacers????
i need a little help here. i bought 19 inch wheels with a 35 offset, BUT i was told for 19's for a c-class i need a 40 offset. is that true and is that what spacers are needed for? i see ppl talk about spacers to make their rims fit BUT i don't know what they are. if anyone can help me that would be greatly appreciated.
Old Jun 10, 2002 | 01:18 AM
sdcaclint's Avatar
C230 kompressor C2 C7
yes that is what spacers are supposed to be used for, just make sure the spacers you get are huh centric, i used the 5mm in the front, and they were not, and it caused a vibration like the tires were out of balance. i think i am going to use my 10mm spacers on the front, and replace the rears with 15mm spacers. i want my wheels to be flush with my fenders. the fronts will be, but the rears will still be a little in. i guess i shouldn't be such a cheap skate, and invest in some staggered wheels. you are doing it right. which wheels did you get? staggered?
Old Jun 10, 2002 | 01:27 AM
silentrage's Avatar
c230 coupe
i unfortunately didn't stagger my rears....couldn't afford to i bought the axis NE-O's in 19's but i'm worried now about this whole spacer thing....sorry i'm a little new to this spacer concept. i bought 19x8 35 offset with 235/35/19 tires....do you think i need spacers? i'm totally confused on what to do now
Old Jun 10, 2002 | 01:53 AM
vadim's Avatar
'19 GLC 300, '19 TM3SR+
Clint--
Where did you get your spacers? Did you use the stock lug bolts with them?
TIA
Old Jun 10, 2002 | 07:58 AM
sdcaclint's Avatar
Autowerksexpress.com is where i got my spacers, and i believe you must use longer bolts. the bolts were made by H&R. but if you are going to take the spacers off, you MUST use the stock bolts again on the back. otherwise you will destroy the parking brake.
