headrests
Old Mar 3, 2005 | 04:38 PM
LowCaliTi's Avatar
Audi 225 TT.w203 sedan.Bmw 318tiCali.Ed.VW Jetta vr6
headrests
has anyone tried to put e-class headrests in thier car? i was told they would fit. i measured both to the best of my ability and they look like they will fit as well. anyone do it or know if it works? and also how do i remove the eletric headrest from my car ? thanks
Old Mar 3, 2005 | 06:54 PM
CclassRun's Avatar
02 c240
why would you want to do that? electric headrests?
Old Mar 3, 2005 | 07:10 PM
CitronC230K_03's Avatar
2003 Citron Green C230KMT
my headrests are electric. if you have full power seats, your headrests are electric as well.
the E-Class headrests look slightly different than the C-Class headrests.
Old Mar 3, 2005 | 11:01 PM
vadim's Avatar
'19 GLC 300, '19 TM3SR+
The passenger headrest in my coupe rattles if extended at full. Dealer could not fix it, and it is no biggie - I just retract it when there are no passengers which silences it fairly well. I wonder if E-Class headrests are any better in this respect?
Old Mar 3, 2005 | 11:30 PM
Outland's Avatar
2002 C230 Coupe(M111)
Did you try removing it completely and bending the rods farther apart? If it can't move, it usually won't rattle.
Old Mar 3, 2005 | 11:42 PM
vadim's Avatar
According to the dealer, that's exactly what they did. There is also a TSB prescribing that.
I guess I have to try just in case - back to WIS search
Old Mar 4, 2005 | 03:47 AM
BrabusCClass's Avatar
GL450, Sienna SE
There was someone on these boards who put in E class headrests in their C class so that they can put in LCD screens in them. Looked nice. I believe they just fit right in.
Old Mar 4, 2005 | 03:47 PM
miroj's Avatar
You need only measure the distance between support posts. Why not visit a dealer ?
Old Mar 4, 2005 | 05:10 PM
ctC230K's Avatar
excites your girlfriend
both or just driver side? my passenger side is manual.
Old Mar 4, 2005 | 05:16 PM
nope, both sides are electric. both front seats are full 10 way power.
my car is a 2003. before they started cutting options.
Old Mar 7, 2005 | 04:36 PM
LowCaliTi's Avatar
mine now are eletric. i want to put eletric e class headrests so i can put lcds in them thanks for the help. i am going to get them ill let you guys now how it turns out
Old Mar 10, 2005 | 02:39 PM
Narcissus's Avatar
2001 C240 Tectite
Can the E headrest, electric or not, move forward/backward like the w203?
Also to anybody having rattling issues from their passenger headrest, bending the rods is the answer, but do not pull them apart, you will break the plastic.. slightly bend each rod one by one with both hands on one rod...
Old Mar 10, 2005 | 02:41 PM
ctC230K's Avatar
w203 headrest does not electrically move forward/backward, you just pull it if that helps
Old Mar 10, 2005 | 02:47 PM
Narcissus's Avatar
2001 C240 Tectite
Ok thanks, I'll assume it's the same for E class...
That is a safety feature that should be on every car....
Old Mar 10, 2005 | 02:49 PM
LorinserCClass's Avatar
The True OG Modded out W203
E Class headrests look just plain silly/weird on a C Class size car. Best thing to do is have a custom pod made to encase your LCD screen on your headrest. Or you can just put screens elsewhere. I managed to slap 4 interior and 1 trunk one w/out resorting to using headrests....
Old Mar 10, 2005 | 05:06 PM
ctC230K's Avatar
they do move up and down electronically though
