Heated seat Question
Old Mar 24, 2005 | 02:07 AM
brabus c's Avatar
Brabus w203
just curious...how many heat pads am i suppose to have in my heated seat option? one for the bottom and one for the lower back? and how many plugs am i suppose to have all together for my seats if i have that option...2 black (bottom cushion/ top cushion) and 1 yellow (heated seat) i have a c240 without the electronic seat option...trying to figure out this stuff because i switched seats with my friends and im not sure if im missing parts or not..thanks
Old Mar 24, 2005 | 08:12 AM
SUNILP's Avatar
2015 E250D
yellow are all SRS related connectors. Should be a black single 4 pin plug. 2 pads each seat. Bottom and lower back.
Old Mar 24, 2005 | 04:01 PM
brabus c's Avatar
Brabus w203
so should there be 2 plugs coming from each seat cushion..2 for the bottom seat...2 for the top seat? i had heated seats from factory and traded them for sport seats...i want my heated seats back but i cant tell if they are mines or not...am i suppose to be able to feel the heat pad if i put my hand under the seat skin? i only have 1 plug coming from each seat cushion and they are both 2 prong
Old Mar 24, 2005 | 09:48 PM
SUNILP's Avatar
2015 E250D
if they are connected, then you should turn them on to see if they work. Each pad has a single connector with 2 pins on it but both connectors are mated to make a single 4 pin connector. You should be able to see this 4 pin connector under the seat on the row of connectors. The wire will be a larger guage wire. You will NOT be able to feel the heated pad. See if the heated seat wire in your car is connected to anything.
Old Mar 25, 2005 | 03:08 AM
brabus c's Avatar
Brabus w203
thanks for your help...
