windshield wiper is out of place
Of course the dealer can do this for you (probably) under warranty because the wiper should have not been loose enough the slip out of register. A 1-inch snowfall should not hang up the wipers. They have worse snowfalls than 1 inch in Germany.
I was hoping that I could simply take off and loosen something to kind of adjust the home position on my passenger blade so that it sits a little bit higher. Bob, would this be the same process as you mentioned above? Also, there are 2 bolts to the bottom of the wiper post cover itself...do I have to remove those as well? Thanks in advance
edit:
I just took a closer look at the passenger side windshield wiper and was hoping to ge things done with Bob's method...thing is...there is also a cover for the wiper post but it leads to two dead bolts pretty much that is pointless to remove if you're just adjusting the home position. The two bolts I mentioned earlier in this post are actually the bolts that have to be taken off to adjust it to the home position I'm guessing? Well I can't get it off with any of the tools I have now (I usually borrow my neighbor's tools but I think he isn't home right now) so I guess I will give it another go tommorow...but can anyone fill me in on one thing...so basically I take off or loosen these two bolts then I just simply move the wiper blade to the position I want? Is this how the process is done? Can someone verify if I'm correct about this process or not.
Can anyone elaborate more on this fix with a diagram?
The problem is that my passenger side wiper travels too far down and hits the plastic casing below the windshield and my driver side wiper sits too far high and unscrews itself if I adjust it to the correct position.
Any advice?
In the instructions shown in post #5, it says:
"The wiper blade must lie exactly on mark A in the windshield screen printing."
Does this refer to a mark on the windshield or is there a template that is laid over the windshield that gives the mark? Can someone tell me where this "mark A" is?
Thanks!
Thanks!
