cracked fog light lens
Old Apr 21, 2004 | 07:45 PM
muscle4lew's Avatar
Veteran: Army
SLC 43, E53
any one replace driver side front turn signal yet???
just had one go out on my coupe....
have not checked how easy it is to replace......
Old Apr 22, 2004 | 11:27 PM
muscle4lew's Avatar
Veteran: Army
SLC 43, E53
turn signal...easy to replace turn/twist..pull out and replace...
Old Apr 22, 2004 | 11:57 PM
Xeon's Avatar
so....anyone has the parts number ?!?!
and i believe i can fit it onto my coupe rite?
Old Apr 23, 2004 | 08:06 AM
muscle4lew's Avatar
Veteran: Army
SLC 43, E53
http://www.midnightmoose.com/
try here.....
Old Apr 23, 2004 | 08:08 AM
muscle4lew's Avatar
Veteran: Army
SLC 43, E53
http://www.sylvaniaperformanceshop.c...op/welcome.asp
TRY HERE ALSO...I did a search and found what i was looking for
Old Sep 24, 2004 | 10:38 AM
wizkid's Avatar
Ford Pinto
Originally Posted by Class C
Hello guys,
My right fog light glass broke aswell last week. I ordered the part from MB, it took a day to come in. I'll post the part number once I dig it up from the trash.
Fairly easy to do, took me 15 min.
Turn the wheel all the way to the right, I feel that it was easier to access the wheel panel, or you could just take off your wheel.
There are three 10mm size nuts that are located on the lower part of the wheel panel
On that same panel there are two snap tight fasteners.
I bought extra fasteners from MB just in case I screwed one up.
Pull the center pin out with a flat head, once the pin is out you could pull out the whole thing with your fingers.
On the bottom of your front bumper you will see 4 or 5 more fasteners, can't remember.
After you pull those out you could pull the wheel panel out to get access to your fog light.
There are two 8mm nuts holding your fog light in place. There are on both sides of the lamp, you can't miss them. Once you pull those nuts out you could push your fog light out from the outside in.
The fog light glass cost me 25 dollars from MB and the fasteners were a buck each.
Hope this helps guys
You wouldn't have a picture or part number of those clips would you? I am about to replace mey driver's side lens and bulb.
Thanks, that was really helpful information.
Eric
www.installuniversity.com
Old Sep 24, 2004 | 10:47 AM
  #32
wingless's Avatar
Debadged 6-Speed '05 C320 Sports Coupe
In addition to my front bumper, fender, hood and mirrors, my fog lamp lenses also have the invisible bra film applied for protection. It is not known if it would prevent this failure, but as is often said: "It can't hurt".
Old Apr 25, 2005 | 09:55 PM
  #33
jigga619's Avatar
2002 C230
Mines just cracked also.. damn rocks.. here's the part number: 215-826-02-90
Old Apr 25, 2005 | 10:18 PM
  #34
wizkid's Avatar
Ford Pinto
I ended up getting a complete write up together about it. www.installuniversity.com
Old Apr 26, 2005 | 04:55 PM
  #35
mleskovar's Avatar
'17 Jaguar XF
Rocks?
Usually it's not rocks hitting the glass that cracks these lenses. Flexing of the air dam/front facia is usually the culprit. Scraping the front or brushing the curb can do it. Mine was broken by a hubcap that shot across the freeway and nailed the right front about 8" from the glass. It's the way they are mounted....in the lense holder and to the bumper cover.
Old Apr 26, 2005 | 07:53 PM
  #36
jigga619's Avatar
2002 C230
Good info..thanks!!
Old Apr 26, 2005 | 08:46 PM
  #37
Saprissa's Avatar
From: San Diego, CA & San Jose, Costa Rica & Stuttgart, Germany
1959 220S / 1979 230 G / 2002 A210 AMG / 2003 C320 SC / 2004.5 C320 SS / 2005 ML350 SE / 2008 smart
Exclamation
Good info..thanks!!
wizkid has a bunch of awesome install tips on that site...
a lot of duplicate posts on here could be avoided, with a quick scan through his site. Thanks wizkid, if I haven't told you before.
Check out the install pics & instructions for the MB warning triangle on the C320 Sport Sedan:
Warning Triangle Installation Post You can use it on your site, if you like.
jigga619, standy by for a San Diego MB meet later this summer !!
Old Jun 21, 2005 | 01:10 PM
  #38
pookie's Avatar
2013 c300 4matic, 2002 c240
anyone install YELLOW foglights? yellow oem-style or yellow clear lens or even yellow bulbs (which is better anyway)? my right foglight cracked so a replacement is in need. i'd prefer yellow since there is lots of fog in the spring and fall where i live and replace both foglights.
