Optimized Fuel Settings?
Old Jun 19, 2002 | 06:28 PM
Duffer's Avatar
2002 C230K, 2001 Audi TT 225 Coupe
Art Coupe
Look at Kleemann's post in this section -- it advances the timing giving more midrange torque
Old Jun 19, 2002 | 06:30 PM
Duffer's Avatar
Vadim, go back and re-read
Kleemann's post -- (one doesn't need to translate an MBUSA setting from Euro specs) 93 is 93.
art_Ccoupe's Avatar
W203 coupe Kompresor
Re: Re: Re: Well, thanks
I'm in Canada but ours here is similar to the European settings.. for octane.. very very simaliar.. actually the same.. i was just told to put in the best.. some gas stations have 91 as highest.. some have 93.. so i would guess it would be just the same...
Originally posted by vadim
Oh, yes... those octane numbers are RON (used in Europe). For the US and Canada they need to be translated into (R+M)/2 as follows:
(numbers are not exact, but close enough)
87RON -> 83US
89RON -> 85US
91RON -> 87US
93RON -> 89US
So, even at the highest possible ignition timing setting almost any octane grade would do.
Now, since the manual says that the minimum recommended octane number is 91 (which is ~ 95RON), it leads me to believe that that's what the "base" setting is. But - again- this is just a speculation.
Old Jun 19, 2002 | 06:31 PM
art_Ccoupe's Avatar
Re: Vadim, go back and re-read
i read it already and didn't really understand it... so i need a dummy explaination...
Old Jun 19, 2002 | 06:33 PM
vadim's Avatar
'19 GLC 300, '19 TM3SR+
Re: Re: Re: Re: Well, thanks
if you have 91 or 93 as the highest grade, then they must be using the same scale as in the States - (R+M)/2. Otherwise you'd see numbers like 95 and 98.
Old Jun 19, 2002 | 06:36 PM
vadim's Avatar
Vadim, go back and re-read Kleemann's post -- (one doesn't need to translate an MBUSA setting from Euro specs) 93 is 93.
I read it very carefully. However, the Star Diag computer clearly says "93RON" etc. RON is not used in the US to measure octane numbers. (RON+MON)/2 is, instead. Hence, the conversion.
It could be a glitch in the Star Diag software - to display incorrect scale designation for the US market - but it sure seems to be one of the things that keeps this debate going.
Old Jun 19, 2002 | 06:39 PM
  #32
art_Ccoupe's Avatar
whatever..
Old Jun 19, 2002 | 06:43 PM
  #33
trench's Avatar
2002 C230 K
I'm pretty sure vadim's right, we had this same discussion a couple of months ago. Somewhere on this site (I'm too lazy to look) someone has posted screen-shots of the computer settings from the Star Diagnositc computer. It specifically shows octane as RON (although this could be incorrect as vadim has speculated). Base is probably the setting for using 95 RON (91 US).
Cheers, BT
Old Jun 19, 2002 | 06:58 PM
  #34
renncpe's Avatar
w203 c230K 2002
Screen Shot
Setting 2 is 93
Setting 1 is 91
Base at least 89
Old Jun 19, 2002 | 07:07 PM
  #35
KJ-TypeR's Avatar
M3
Now that we see that the computer shows "At least 93 ron" which equals 89 Octane in the U.S., wouldn't it make sense that the "BASE" setting = 95 RON?
The computer has 89 RON, 91 RON, 93 RON, and then BASE. By following the pattern, I'd guess the next step up would be 95 RON. (Number increases by 2 everytime).
The owners manual says "Car needs 91 Octane or greater".
Since 91 Octane = 95 RON, this also implies that BASE = 95 RON = 91 Octane just like the manual says.
Even the computer screen shows that "This correction is used to retard the ignition timing in order to prevent the engine...fuel is poor".
IMO, I'd leave the setting as is.
Old Jun 19, 2002 | 07:10 PM
  #36
renncpe's Avatar
w203 c230K 2002
It says values of ron at least 93 octain. not 93 RON.
Randy
Old Jun 19, 2002 | 07:11 PM
  #37
trench's Avatar
2002 C230 K
Notice the screen shot says, "the correction is used to retard the timing to prevent the engine...when the fuel is poor." This implies that all of the corrections retard the timing - there isn't one to advance it for better fuel quality and that base is for 95RON/91 US.
I was inspired to find the other thread on this same topic:
https://mbworld.org/forums/showthrea...&threadid=6756
BT
Old Jun 19, 2002 | 07:14 PM
  #38
Lynn's Avatar
I agree with your reasoning. I would like to know how our bureaucrats came up with that stupid average of RON and MON crap. I propose that we call it the Stupid Obnoxious Bureaucrat's Octane Number or SOB'sON for short.
Old Jun 19, 2002 | 07:36 PM
  #39
Buellwinkle's Avatar
So, if by chance a larger crank pulley makes your car ping because of crappy gasoline in your area or high heat it may pay to have it set to 93 or 91 to retard the timing a little bit to prevent the ECU from retarding it a lot at high RPM. Or is the ECU adaptive enough to figure out that you are pinging now and then and adjust the timing curves on it's own.
Old Jun 19, 2002 | 07:57 PM
  #40
vadim's Avatar
Re: Screen Shot
Originally posted by renncpe
Setting 2 is 93
Setting 1 is 91
Base at least 89
Randy - could you please post a screenshot with the "base" option highlighted? That might put an end to endless speculations (if it shows the octane number it represents, that is).
Old Jun 19, 2002 | 09:03 PM
  #41
avlis's Avatar
2008 VW GTI
Randy
The term "octane" is used in RON
Research
Octane <---
Number
This leads me to believe that they are using RON units even though it reads "octane" in the pull-down. Europe octane is measured in RON and ours is xxx... Either way, it's still considered OCTANE and that's what's shown on the pull-down. I think KJ-Type R is correct.
RANT: How many people work in Mercedes engineering? And NONE of them read this board????? Nobody can help us here?!? WTF!?!?
Old Jun 19, 2002 | 10:15 PM
  #42
renncpe's Avatar
w203 c230K 2002
There is no confusion here at all. If you have a ping problem that is caused by poor fuel you retard the spark. the top setting allows for the most advance for 93 Octane or better. the second setting less advance for 91 Octane and so on.
Randy
Old Jun 19, 2002 | 10:20 PM
  #43
Randy
I think the confusion is that, is the 93 on that menu screen RON like what they sell in Europe or (RON+MON)/2 like what the pumps in the U.S. sell? The confusion is that is says RON on the screen but some think it's (R+M)/2. If this is the case, what is BASE, is that the default the car comes with? Is it RON 95 as some speculate?
BTW, you have a pulley, what octane fuel do you use and do you have any issues with it?
Old Jun 19, 2002 | 11:04 PM
  #44
Brandon @ Kleemann's Avatar
Former Vendor of MBWorld
Randy
Thank you for your professional input! This should cease the confusion about advance or retard at the very least.
Just as a side note: when was the last time anyone saw 83 octane gas at the pump??? The last time I saw gasoline this poor I was in South Korea.
Old Jun 19, 2002 | 11:10 PM
  #45
TimmyC230boy's Avatar
From: Sitting behind thing freakin desk of mine. Dreaming I was playing my Taylors, and driving my Benz. Long Live The VRAA!!!!!!
C230 Sports Coupe
and what have we learned class.
USE THE BEST FREAKING GAS YOU CAN, AND LET THE ECU MANAGE THE IGNITION.
Old Jun 20, 2002 | 03:09 AM
  #46
renncpe's Avatar
w203 c230K 2002
I run settings for 93 octane and fuel quanty setting of 3. I saw that some with the chip set were haveing ping with the chip I wonder if they had advanced the timeing in the ecu settings in addition to the chip? Side note Renntech is working on a flash program for the ecu that does not require installing an on board chip for the Simmions ecu. There is alot more to the ecu programing than fuel maps and timeing....
Randy
Old Jun 20, 2002 | 09:08 AM
  #47
KJ-TypeR's Avatar
M3
Not everyone has learned so far. Some people are so stubborn, they won't listen!
Old Jun 20, 2002 | 09:18 AM
  #48
mdp c230k's Avatar
2002 c230k
[QUOTE]Originally posted by avlis
[B]
Research
Octane <---
Number
So?
M = motor
O = OCTANE
N = number
Old Jun 20, 2002 | 09:40 AM
  #49
KJ-TypeR's Avatar
M3
So?
M = motor
O = OCTANE
N = number
MON = Measured Octane Number
Old Jun 20, 2002 | 10:21 AM
  #50
mdp c230k's Avatar
2002 c230k
WRONG! it IS MOTOR OCTANE NUMBER
http://www.faqs.org/faqs/autos/gasoline-faq/part1/
Its a long boring read, but it is correct.
