HELP...with electrical question on a seat install
underneath the passenger side seat there is a box with 3 electrical connections to the car. there's a white one and 2 yellow ones. upon removing them i realized that the SRS error indicator goes off and the airbags shut off. so i then figured out that the white one had nothing to do with it...but the 2 yellows did. one of the yellows was the belt buckle sensor...i was able to totally remove it so that it can be used with the new seat.
however, when i followed the second yellow connection, it led me inside of the cushion of the stock seat...is this something i have to pull out of there? or is there another way around it? because i wouldn't want the SRS error message permantently there, and would definitely want the airbags to work properly.
any advice??? the instructions from recaro have no mention whatsoever of this...by the way, my seats are manual
-s-
the only one i can think of is steve..but he's not in nj
i think the best option is to find someone with star diag that can shut it off...or to trick that circuit into thinking its ok (with resistors or something)...i heard that using a 3 ohm, 1 watt resistor can do this...we'll see
I did talk to the sales rep who sold me my Recaro for my driver's side, and he said that Recaro sells a resistor for it, which would then fix the problem, so that the airbag's already armed (which is pretty fitting). I haven't yet decided if it's worth another grand to the passenger's side, though.
