Harmonic Balancing and Pulley Systems
i was told that dinan had written a paper on the importance of maintaining the harmonic damper/balancer but i could not find that reference. w/out a long term study on the engine, who knows?
What the factory pulley has is a rubber like damper. It's basically a groove cut into it that you can see from the back and is filled with some kind of flexible material (maybe rubber or a synthetic rubber, I don't know). I took pics of it before and posted it but it's hard to see the black rubber on a black pulley. Check my install instruction for the rear view picture of the pulleys. The slighly uneven ring of rubber can be seen there. What I've been told that it's to dampen vibrations from the pulleys and belts to the crankshaft at certain rpms. Yes ASP has taken this into consideration and designed it in a way to mitigate this issue. They make crankshaft and supercharger pullies for various cars, many with way more power than the coupe and that's what they do best. I would assume that Kleemann with his vast experience with MB motors factored this into his pulley.
I think there's some misinformation floating around. A harmonic balancer is a mechanical device with counter weights inside that pulse in opposition to the pulses of the engine to make it not vibrate as much. I had harmonic balancer put in my Harley to reduce engine vibrations for comfort. These were common on V8's to reduce vibration.
For those that come to the BBQ this weekend in San Diego, I'll bring the factory pulley/damper. See that bugger for youself.
