19x9.5's from Audi to my C240...
Thinking of putting my Wheels (Axis) from my 02' A4 onto my 04' C240. The problem is that I'm running a 275/30/19 and they are a 45mm offset. What size spacer am i gonna need to run in the rear to get these to work? any thoughts on where to pick a 2 rear spacers to get these to work?
BTW- the fronts are the same offset..
thanks,
Darin
thanks,
Darin
you have to be kidding? A 275 will not fit in the rear? I've know people who have run them on their C with H&R's and had no problem. Also if that is the case, what are people using for tires that are running 9.5's and 10's? I think they will work I just need to get the offest correct.
..so is 35 or 38 the offset that needs to be run in the rear for it not to rub with 9.5's and 275's ?
Darin
Darin
Administrator
![](https://staticssl.ibsrv.net/autocomm/Content/MB/mbwambassador2.gif)
Darin
Darin
Darin
Darin
Thanks! I know you can run it. people gave us hell with running stagged' on our A4's w/ quattro. never had any issues with them and was able to run 275's all day without having to roll the fenders. My ? to you is wheredid you get those spacers? and who/ what did they use to roll your fenders?
I think if I go with a 10mm I should be ok...that will bring it to a 35mm offset.
TIA,
D
TIA,
D
TIA,
D![thumbs](https://mbworld.org/forums/images/smilies/thumbsup.gif)
TIA,
D
![](http://img263.imageshack.us/img263/8209/190041nc.jpg)
![](http://img263.imageshack.us/img263/660/190000ce.jpg)
![](http://img263.imageshack.us/img263/286/190038xp.jpg)
