View Poll Results: To tint or not to tint
Yes
340
90.19%
No
37
9.81%
Voters: 377. You may not vote on this poll
Tinted Windows W203 Thread - All You want to know about window tinting a C Class
Originally posted by Mach430
If you have the normal MB window moldings (which are abrasive) you will scratch your tint within 6 months. Make sure to have your window moldings replaced with a mole-skin or felt compound instead to prevent this. It's fairly cheap, especially when comparing it to replacing your tint job. For more info, call Vision Tint in the 714 area code (Orange, CA).
Just some thoughts...
I was planning on tinting the windows of my C32 but after all the talk I have heard about the tint getting scratched up I have decided to just live with the blue tint it came with. I assume the scratching problem is with the tint on the windows that roll down.
when you roll down your windows you'll notice that there is an internal and external (refering to the interior and exterior of the car) gasket that buts up against the glass where it meets the door. That seal or gasket, or whatever you want to call it, gets tighter against the glass because of the added thickness from the tint and can lead to scratch marks on the tint.
#32
i just picked up my c230, 6 speed, cd, c7, c2, silver, tinted windows. I had the dealer do the tint because they give life time on scratches, fade etc etc....according to the dealer this is some new material that will last as long as the car and then some and it also has a built in sun screen for UV rays. Of course it was 2 times as much as i could have had it done out side the dealer but some times it is better to spend the extra if it means less time and effort later.
will be posting pic soon
#34
b4chow,
I read on another forum/posting that someone replaced the window seal...similar to what was posted earlier on this thread by vince....someone replaced the factory window seal with one with mole skin material and eliminates/reduces the scratches. Sorry, but i forgot the specific forum/posting...hope this helps out
#36
#37
link for window tinting
I hear that the attached link was recommended by one of the MB dealers. I have heard good things from people that have used them. I like the blue.. so Im not tinting any further.
The name is http://www.huperoptik.com/
#38
Originally posted by Dummkopf
For Mach430,
Tried to call Vision Tint in the 714 area - but they're not even in the phone book - please advise!
For Mach430,
#39
Tinted windows? Do you have lines?
I tinted my windows and found that there are lines that cut into the tint. Does anyone else have this problem on the new C's? The lines are obvioulsy caused by the windows going up and down.
Can anyone explain why this is occurring? I'm guessing that there are "rollers" inside the door panels that are cutting into the tint....It's so bad that I'm considering having my tint removed.
Also, don't tint the back window with a metallic-based tint. It will cause poor AM reception!!!!
Spin
Spin
#40
2004 Civic Si. FWD for the Win!
I'm reminded of the line in "Revenge of the Nerds": Pan down!!
Keep going down; you'll come to a discussion of this very topic; it seems as though the trim around the window frame has a tendency to scratch tint, as you've found. People have replaced this trim with "mouse fur" trim to correct the problem.
Speaking of trim, the next line in said movie, of course, is "We have bush!" Ah, the classics...
#41
Cause:
MB window moldings since 1996 have been made far too abrasive to support tint. Why they did this, I don't know, but it ruined my tint!
Solution:
Contact your local tint shop and ask them about moleskin, felt window molding replacements for your windows. If they don't know about it, call Vision Tint in the 714 area code. They're located in Orange, CA off of Tustin and La Palma.
Solution:
#44
Tint | What kind should i get?
What kind of tint would look the best on the coupe.
I love the blue tint that comes on AMG and sport models. But don't know if any place can do that.
then there's the simple black tint. and also the tint that is has a slight metallic look to it.
My coupe is black so keep that in mind.
thanks
thanks
#45
No matter which tint you choose, although I suggest black, make sure you have your window moldings replaced with either moleskin or felt moldings. As I've stated before, the stock Mercedes window moldings are very abrasive (you can see it if you look), and will scratch your tint over a few months. If you need more info on it, call Vision Tint in the 714 area code (Orange, CA off of Tustin and La Palma).
#46
Most tints will scratch
Here is a link for a company that supposedly works well with Mercs. I dont have it but from the various sites I visit, this one comes up often. Hope it helps.
#48
Tint Properly
The secret to a nice tint is getting a smooth gradiant all the way around. IMO, having a drastic change from the back to the front makes the car look tacky. My recommendation for tint is to use 25%-35%-50% (Back Window - Rear Sides - Front Sides). This will give you a nice smooth blend that will make tint almost look factory. I have gotten away with tinting the front using this method.
#49
i went with 20's on the rear and back doors and 35's in the front. I wasn't too fond of the 50% tint because there was hardly any difference.
35% all around looks just dark enough to make a difference but still light enough to not get the attention of the law. If anyone is interested, i'll try and post pictures
20% all around will definitely get you some attention but not the kind that you like..
just my 2 cents....
just my 2 cents....
