Springs & Shocks
Old Jul 5, 2002 | 12:13 AM
peterrrrrr's Avatar
2002 C230 K
Springs & Shocks
I don't see anything specific for our car on the "suspension forum.
Has anybody found a suspension modification of both springs and shocks? It apears that H & R has just springs. Any feedback on these with factory shocks?
It looks like Kleeman has both.
Any feedback including cost and installation would be appreciated
Old Jul 5, 2002 | 12:23 AM
Lynn's Avatar
If you lower your car, you should change to shocks of the corresponding length. The stock shocks can be too long, and may not be stiff enough. Koni adjustable shocks and Bilstein gas filled shocks are very popular. H&R and Eibach retailers can help with the selection of shocks.
The Kleemann suspension is reported to be outstanding, but it will set you back about $2000.
Old Jul 5, 2002 | 02:14 AM
BlackC230Coupe's Avatar
Former Vendor of MBWorld
Fast Cars!
Re: Springs & Shocks
i have H&R springs with RennTech Shocks. U can get shocks alot cheaper than those. and just as good. But at first i just had the H&R springs and the ride was still very good.
Old Jul 8, 2002 | 11:02 AM
Class C's Avatar
W203
I just lowered my car with H&R's, my ride is excellent. Until I feel like my ride starts going to hell, then I'll purchase shocks.
Old Jul 8, 2002 | 11:09 AM
Boo2's Avatar
C32 AMG
I'm using Carlsson springs. Improved handling over stock but not as stiff as H&R. Good compromise between look and performance. Ii is actually slightly lower than the H&R drop.
Old Jul 8, 2002 | 11:45 PM
peterrrrrr's Avatar
2002 C230 K
Thanks for the comments guys
After doing a lot more research I have found out that with a good set of springs you can get vastly improved handing without changing the shocks. If the car is lowered around an inch then you don't have a problem with the length of the stock shock. I am having Kleeman springs installed in a few days. I'll let you know what I think. We can always change the shocks later.
Also having a Kleeman pulley installed
C_CLass
What is a sport Grill?
Old Jul 9, 2002 | 01:15 AM
Lynn's Avatar
The sedan sport grille looks like the coupe grille with the star.
Old Jul 9, 2002 | 11:54 AM
zpeed's Avatar
C240/6 Megma Red
Any problem with the alignment? Can it adjust back to the factory spec both front and back. Is the alignment adjustable for both front and back (both camber and toe)? I'm refering to C240 w/ only spring not the cup kit. I'm shopping for the spring now (I might go with H&R).
Old Jul 10, 2002 | 02:35 PM
kineda's Avatar
BANNED FOR VIOLATING TOU
C230k
Anytime you lower your car you should get an alignment.
Old Jul 10, 2002 | 03:30 PM
zpeed's Avatar
C240/6 Megma Red
I know that and my question is
Can it adjust back to the factory spec both front and back?
Do I need an alignment kit? If I do need where can I get it. BTW I just order H&R spring.
