NEED HELP ON HOW TO INSTALL 20" RIMS
if you really want to make them fit, you car put on 15 inch spacers so that they are outside your wheel wells
it cant be done. especaillly on that tire size. u can roll your fender all you want and stiffen ur suspension all you want it will not work.
plain in simple show me someone who made it work, i know some people claim that they have made it work but it is impossible without rubbing. the reason being the front is too big and rubs when it turns.
take it from someone who has tried
btw: ur screwed return the rims take the loss
Sinyo1 has 20's
https://mbworld.org/forums/showthrea...ghlight=sinyo1
ps
hey MERCEDES,i think my english is good enough for me to independently buy a w203 considerring im only 18
Sinyo1 has 20's
owned
running 20" on the C is doable with a lot of work in the fender, but it is also more stupid than us people running 19" for looks. It doesn't matter what tire you run, 20" is going to be way oversize. The 235/35/19 is already oversized. The only reason people chose this size is because for front wheels 19's are usually 19x8.5 which if you run 225/35/19 (the closest diameter to stock 17) you will leave the rims unprotected.
M3s can run 20" inch because they have a much larger clearance inside the fender with those semi widebody stock look. Also stock vs stock M3 is already using 235 tires for 18" which yields a larger diameter than our car on 18 which we only run 225.
I'm sure you dont' want your car to look like this
I think for our cars, 18's and 19's are the way to go. 19's are pushing it, IMO, but 20's? Forget about it.On another note, does anyone else feel that Hummer H2's and H3's that have 20+" rims installed are a bit self-defeating?
Just because some lame rap/rock stars "pimps" their rides with bling bling 20's, it doesn't make it okay for everyone else to look stupid with them and follow suit!
Oh well, to each his own.
Dont trust that widew203 guy he is posting another members car(Pudgy):p
