DVD vs CD Nav
Now for the question, what is the difference between DVD and CD Nav, any graphic difference, any added options??? Of course the DVD one will be better, but just wanted to know if there is not much difference may be I can save $1500 and get the CD nav. And how hard is the installation, and how much it costs?
And lastly will C-230 CD Nav fits C-320 sedan, both 2002 models...
2004.5 - = CD nav
Any questions?
I asked the dealer and they told me the Comand doesn't play burned CDs and that it's having problems ejecting them because they're thicker. Is this true?
I took the same burned CDs and used them on another car CD player. Worked just fine. Either the Mercedes Comand really SUCK, or it's malfuctioning?
Anyone else with Euro Comands having this problem?
Eject is subject to the finish of the topside of the CD..the eject rollers do not have enough grip on some finishes...if the CD doesn't eject right away - you can simply press the disc down with your credit card while it is ejecting.
The older a CD rom comand gets - the more dust accumulates onto the rubber rolers and that results in less succesfull ejecting of the disc.
greetingz,
In your first post, you stated both cars are 2002 MY. In that case, DVD navigation is NOT compatible, unless of course you're as crazy as Sunman and do a whole bunch of changes just to retro-fit the MOST system into your car. The MOST system came stock as of 2005 - present.
That's why Sunman says that he's had BOTH in his car, but if you search on the boards, I'm sure you'll find the multiple postings of how much work was necessary for him to change everything (almost literally).
greetingz,
greetingz,
The keyless go working okay? Man, despite all the $$$ that must be going into your projects, I'm sure it's all pretty fun to play around with the different functions...especially because it's all OEM.
