renntech pulley installed and i feel pretty good...
Buell,
When I do get my pulley it will be from Kleemann, a name I can trust. His is lighter than yours and he has years of MB experience that make it worth it. I find your new found 'expertise' no match for the real thing.
Less expensive = cheaper
Bull still can't answer why the pulleys are with in fractions on an inch is size why there is such a diffrence in output. And no a lighter pulley does not make more HP. Kleemans is lighter than Bulls with out a corresponding diffrence to HP when compaired to the renntech pulley and it's weight.
Randy
My pulley will be coming from ASP. Thanks Buellwinkle.
can you now find the dot-epa regulations that the pulley will void? thanks.
So one question to ask Renntech is have they complied with EPA regulations and performed these test or is the pulley for off-road or racing only? This would be proof that they actually did test their pulley in real testing, not just driving around.
Has other pulley companies complied, not that I know of but it's possible. If they have then you are covered under the EPA clean air act and MB can not void your warranty, if they haven't and they say off-road use only then you are on your own. Harley has a different company called Screaming Eagle for this very purpose. Put on a Screaming Eagle part and they don't have to honor the warranty. Most dealers now refuse to put these parts on even though they sell them.
Also, remember that these are Federal laws. If your state uses guidelines similar to the California Air Resource Board then the actual part has to be tested and an OE number assigned. You can fail smog testing with just a visual inspection without this number. Is it likely that they'll notice a complete solid pulley during a smog test, no, is it possible that they may notice a pressed on or scewed on ring with a tuners name in bright white letters, maybe. Worst case is you can get a California red sticker registration for non-comforming off highway vehicles and use it for racing only.
....And no a lighter pulley does not make more HP. Kleemans is lighter than Bulls with out a corresponding diffrence to HP when compaired to the renntech pulley and it's weight. .....
Randy
Its the same idea as throwing a 5lbs ball compared to a 10lbs ball- given your arm has the same strength- which ball can you accelerate to X speed quicker?
That because the engine was 'detonation" and so with colder plugs, it show a gain but if the engine was not 'detonation" then the colder plugs properly wouldn't gain any hp from it. Is this right, Kleemann?
The MB dealer by me has a dyno and they'll set the ECU settings for more fuel. I just have to call them and make the appointment with their dyno department. I can have them try stage 2 and stage 3 and see what results I get. I told them about the pulley and their cool with it.
i have read about the extensive testing done on the higher priced pulley systems. so i assume they must also be charging to recoup the costs involved in complying with california's strict smog laws. i would expect nothing less from the "leading mb performance" companies.
randy or brandon are your products CARB legal?
A lighter pulley does not MAKE more HP- it just wastes less HP spinning it up. And -yes- there is a difference in power produced.
Randy
Randy
I'm not a tuner, I'm a proud hot rodder for many years. Hot rodders are like tuners but without the stench of caviar on their breath
Randy, what you are saying is that the Renntech pulley has not been EPA certified and is for off road/racing use only. Does that mean that if you drive it on road you're a federal criminal (LOL). I use my car with ASP pulley only on a closed circuit race course and then I take my pulley off for street driving (LOL).
So is that BS on your breath???
Randy
?Another Bullism? you to suggest that the only legitimate testing for tuners and there mods is to do an EPA study? You had a knock off pulley made. And then? You attack other people for choosing there mods as they see fit. You are not a tuner you just play one on the message boards. Give it a break let other people enjoy there cars and there Mercedes experience with out your badgering, and your misrepresentations.
Randy
You did not answer any of the questions. Are you waiting for some body else to answer them for you???
Randy
To think that you believe the steel appendage on a factory pulley can compete in power to a pulley like Kleemann's or ASP's. I thought you are a tuner, one that knows all, the master of the MB universe. Any hot rodder knows that if you lighten the flywheel & crank pulley you will get more HP or do the laws of physics evade Renntech?
BTW, do you work for Renntech? I thought you work at an MB dealer in Florida.
What questions? I answered some off line using e-mail and PM. I can't give away all my secrets
Randy
i notice that you like to use extreme exaggerations to make your points but that is why i tend to disregard a lot of your spoutings. and that is a disservice to everyone.
to clarify, i repeat, buell, that you are the only person that said renntech covered the engine. renntech nor i have ever said that.
your quote: "The Kleemann pulley is not out yet so if you want something that's been out for while get the Renntech. They provide a warranttee that their pulley won't damage your engine, nobody else that I know does this. No offense but you sound name brand aware and Renntech is the famous U.S. MB tuner that most people know." it was only upon my questioning of that did you backtrack.
Based on what I've read on the Renntech warranty, you are not covered if you abuse the car yet you can only race it or drive it off road, seems like a contradiction used by suits to avoid having to pay claims or answer to the feds. So I would believe it if you tell me that they have never paid out a warranty claim. I just distrust companies with legal mumbo jumbo that's contradictory and worded in a confusing matter that makes it virtually useless. I'm just saying that if they told you something else like it's OK to drive it on public roads then you should get that in writing. It may come in handy someday and keep the FTC phone number handy.
Dr. Killjoy
That was based on statements (young) said...
your reply, also dated 6/15, "I've heard about the warranttee about the Renntech pulley but I've never seen it. Can you call them and ask exactly what the warrantte covers so it put's this issue to bed."
after i contacted renntech, my post dated 6/17, "my interpretation is for me, 3.5 years of warrantee. and they will pay for labor of installation of the new pulley."
please don't say that your misunderstanding is based upon my statements when that isn't true. i do not know where you got that idea but it isn't from me.
your quote is from thread previously linked. the second thread is https://mbworld.org/forums/showthrea...threadid=10342
Like I said before, all the pulley warranties are bogus because if a pulley cracked, fell apart, warped or otherwise created a valid warranty condition there is no way that I would put another one back on my car, regardless of who made or installed it. I would certainly accept my money back but that's not written into the warranty, is it.
renntech - upto 4 years for pulley and labor. labor at an approved Mercedes dealership. Renntech, very reputable company that i believe will make a good faith effort to remedy a problem should it arise.
kleemann is fine but shorter. 1 year parts and labor at an approved kleemann shop. Kleemann, very reputable company that i believe will make a good faith effort to remedy a problem should it arise.
asp... well, 1 year pulley free from defects. um, no reputation to speak of to me - good or bad. are they going to care if your car breaks down?
you see no difference in the warranties from ASP w/ the Kleemann or Renntech? if you say yes, then, again, there is nothing more to be said.
i would be happy w/ either the kleemann or the renntech - both make great products - tested and proven. but i am not comfortable w/ the ASP pulley in my car. i'm sure it is fine in yours.
