Will MonoBlock VI 8.5 ET35 fit sportcoupe front with AMG brakes?
Old Sep 20, 2005 | 04:41 PM
rubensans's Avatar
Brabus K3
Hello,
Normaly front Monoblock VI 18' 8.5 wheels should be 18' 8.5 ET30; will ET35 clear AMG brakes?
Best Regards.
Old Sep 21, 2005 | 01:30 AM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
Originally Posted by rubensans
Hello,
Best Regards.
you can just order spacers from Brabus.
Old Sep 21, 2005 | 01:47 AM
mig888's Avatar
EVE
they should come with 5mm wheelcentric spacers... well at least mine did... (not that i needed it for that reason)
flip
Old Sep 21, 2005 | 01:50 AM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
when you order from Brabus and stated that it's for the W203 or W209, they'll include the 5mm spacer that can be secured to the wheel by way of screws. when it's for other model they exclue the spacers, but you can still add them on.
Old Sep 21, 2005 | 02:08 AM
mig888's Avatar
EVE
These are THE ONLY spacers I would use as well. Other wheel companies need to follow suit! BTW, brabus also sends bolts and necessary hardware for these spacers (varying in size).
flip
btw: frank, do you have a picture of what brabus wheel locks look like? (i've been told these exist, but mr. google doesn't know either).
Old Sep 21, 2005 | 02:24 AM
rubensans's Avatar
Brabus K3
But the spacers comes to front wheels or rear wheels?
612-858-30RDK 8.5J x 18 H2 offset 30* € 480.00 15.00
front possible tires: 225/40 ZR 18-88 € 385.00
612-958-35RDK 9.5J x 18 H2 offset 35** € 580.00 15.00
rear possible tires: 245/35 ZR 18-88 € 400.00
or 255/35 ZR 18-90 € 470.00
**203-106-90 modifications required VERSION II € 450.00
for sufficient wheel coverage and clearance with 18“ wheels
Best Regards.
Old Sep 21, 2005 | 02:41 AM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
flip
they do exist, but I don't have pictures for them. They retail $75 btw.
Old Sep 21, 2005 | 02:45 AM
mig888's Avatar
EVE
You know more specifically if they sell them mix and matched? i.e. 5mm locking bolts and 10mm locking bolts? TIA.
flip
Ruben, they send the spacers to be used in front.
Old Sep 21, 2005 | 02:52 AM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
flip
you'll have to include what wheels and model of car you have so they can send you exactly what you need.
Old Sep 21, 2005 | 02:57 AM
rubensans's Avatar
Brabus K3
Then I can take a offset 35 with a Brabus bigger spacer and it will be the same?
Best Regards.
Old Sep 21, 2005 | 03:34 AM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
Best Regards.
The mono VI for the W203 comes with the 5mm spacers. The wheel itself for the front 8.5 is ET35 plus the 5mm spacer the ET = 30.
Old Sep 25, 2005 | 07:09 AM
rubensans's Avatar
Brabus K3
Are you sure about this?
The the: 612-858-30RDK 8.5J x 18 H2 offset 30 is in fact a 35 offset wheel with a 5mm spacer?
Best Regards.
Old Sep 25, 2005 | 01:33 PM
DACHIGGA's Avatar
2002 CL203
Yes he's right. You will need to use the 5mm spacers.
