Trunk Handle Question
1) Does the trunk handle come as part of a frame or is it a separate piece that can be used in conjunction w/ a frame? (The picture on mbusa wasn't too clear)
2) If it can be used w/ a frame, my next question is whether or not the screws would be long enough to work w/ one of the frames on the mbusa site. I seem to recall talk of screws not being long enough for the trunk handle.
I'm thinking the "Polished Stainless Steel Slimline Frame" would like nice w/ the trunk handle.
The trunk lid pops up by itself, so there's no need to manually pull on a trunk handle... In the fully open position, the license plate trunk handle points to the sky... generally useless unless you're Shaq O'Neill. While the handle in the underside of the trunk lid is exposed (facing you) to assist in closing the lid.
Just suggesting you stand at the trunk and play with it a few minutes to understand the ergonomics involved before buying one of these.
Buy one if you like the look, of course. But I wouldn't describe it as a functional addition, IMO.
However, are you aware that there exists a trunk handle in the under-edge of the trunklid itself?
Yep, I do use this to pull it most of the way down....but I still need to touch the rear deck lid to give it the final push.
Well, what you do is put some force into it and "throw" the trunk lid down so you do not have to touch the paint to close it. Works fine for me.
Hmmmm. I'll have to try that.....then I could save the $19 by not buying the handle
Oh those clever german engineers!!!
Smoky
)That being said, I just bought the slimline frame and handle. I'll take a picture of it installed if anyone is interested.
Ok, I tried throwing down the trunk w/ the interior handle. While it is definitely doable, it does take some skill (My wife would never be able to get it to work
You're right. You have to have to put some force into it, yet execute the motion so your hand gets out of the way. Hehe, whatever works for you.
SF, the only problem that I had was that I've got an alumni plate, and the combination of the handle, the script lettering at the bottom of the license, and the "Mercedes-Benz" at the bottom of the plate frame combined to make the screws too short. But then I changed the frame to a simple one with the "M-B" on it, and it now fits like a glove. I really like it, and for $19, who can complain?
1) It doesn't stick out much and isn't much of a handle
2) Closing your trunk with a handle held on by 2 tiny screws doesn't seem like it will last long. It seems flimsy at best.
Oh well, I put the screw caps on before testing it so I'll just leave it on.
I have no idea why you people insist on slamming the trunk lid. It's not really supposed to be closed that way!
. She once drove some older relatives somewhere in her car. She told me her aunt kept slamming the rear door to be sure it was closed. When she got home, the rear power door lock module had come loose inside the door and had to be fixed -- luckily, under warranty.
My wife likes to "slam" everything, including the glove compartment door. If she opens it, now I have to always remind her that it just takes a gentle push -- I mean you don't have to break the thing, right
. I plan on putting the trunk handle on my C32 when it arrives aswell, even though I will never use it.
