Ipod for Comand w203 (A 203 827 52 42)
W203 slightly modified
Originally Posted by frankyweb
is it possible to install Ipod on navigationsystem comand? the model is
(A 203 827 52 42).
(A 203 827 52 42).
DVD COMAND uses the iPOD kit
'08 BMW e92 335i
Originally Posted by benzmodz
CD COMAND uses the ICELINK in place of the CD stacker.
by CD stacker you mean we would lose the option of it?? so cd stacker(changer) or ipod only?
![Red face](https://mbworld.org/forums/images/icons/icon11.gif)
Originally Posted by sunman
yes that is correct. in older d2b based comands, you lose the changer with the use of icelink. In newer MOST based comands, you lose your aux input.
'08 BMW e92 335i
thanks Sunman.. Just read some of the details on your mods on your site.. what's the difference with the w211 cluster vs. the <05 w203??
Not to sure on command but on my audio 20 I had a bunch of wires connected to this sort plastic connectorwich you had too undo and add like an extension (y lead) for the ipod when I plugged it all in cd changer no longer worked but I just found the cd changer plug and plugged it in on the plug at the radio, if that makes any sense.
sorry i don't know all the correct terms!
https://mbworld.org/forums/audio-electronics/121546-no-cdc-no-phone-after-ipod-kit-done.html
Seems to be a common problem with novices.
The installer made a mistake. He didnt connect the fibre optic to the new connector.
https://mbworld.org/forums/showthread.php?t=121546
why not just test it before they plug everything back in again????
![hammer](https://mbworld.org/forums/images/smilies/bonk.gif)
why not just test it before they plug everything back in again???? ![hammer](https://mbworld.org/forums/images/smilies/bonk.gif)
