Part Number for the Motion Sensor Unit
Does anyone have the part number for the motion sensor unit that mounts in the ceiling of the car?
From what I understand, there should be a modular plug under the headliner for the unit to plug into. I understand that I would have to cut the headliner to install this.
Does the part number vary with the trim package? eg, does it change depending upon the color of the headliner?
what would the number be for a Black, 2006 C230 SS?
what would the number be for a Black, 2006 C230 SS?1270 PEPPLE
1421 QUARTZ
1451 JAVA
7220 ORION GREY
7376 ALAPACA GREY
Should be ordered according to your car interior. This is only valid for the sedan, wagon and coupe with normal sunroof.
in short: good luck
greetingz,
in short: good luck
greetingz,
in short: good luck
greetingz,
Thanks for the info Citron, you always go the extra distance.
Is there a part number for the harness needed? Or do you need to crimp your own? Is there a part number for the steel frame?
I often need to sneak wires into blind tricky places. I use a very flexible fiberglass rod (familar to those who install cat5 cables in existing buildings) with a chunk of steel on the tip. When the rod is inserted into the headliner, I use a magnet on my side to guide the tip around objects like the sunroof.
I got a tip from a Dutchman working in a Malaysian car factory for installing plastic assemblies with barb fittings. He would wipe a finger "wetted" with lanolin over the sliding surface of the barb. Worked well, and the lanolin, unlike vasoline, does not go rancid or move from where you apply it. Would work great to install the motion sensor in the metal frame.
I had to replace my antenna on a '92 Passat. To do that I had to drop the back end of the headliner. I got scraped up and ended up with a loose flap of fabric on the headliner material. Fortunately I have access to the spray adhesives that they use to put the material down with and I was able to repair it. I really do not look forward to a repeat experience.
Please check out the following post #'s
of my AMG Euro SportsCoupe A La Mode thread:
# 201 - IMS Part Numbers
# 362 , 363, 364, 365 - IMS Install
most, if not all, of the questions asked in this thread, have been answered there already.
Carlos
Saprissa@aol.com
Who wouldn't want a Coupé ?
That thread has tons and tons of good info.... Too much of it is now burried in there, as the thread has gotten longer and longer....
Lots of DIY jobs, lots of part #'s, lots of Coupé only retrofits and mods.
and my favorite: tons of pics !
Carlos
Saprissa@aol.com
It's not an urgent project, but if anybody in So-Cal has done this before or can refer me to a shop that can do it for me, please let me know. Carlos' step-by-step is for the coupe, so I'm figuring there'll be slight differences with my sedan.
TIA, everybody.
drex
