Floored gas pedal... then a click
Old Jul 20, 2002 | 03:07 PM
preyx's Avatar
'02 C230K Coupe
Can't you just override the speed setting by just pressing the gas? The reason they have that there is so you can pass other cars without cancelling cruise control. I never heard of increasing the speed past what you set it at only by kickdown.
Old Jul 20, 2002 | 03:09 PM
mverboom's Avatar
C270CDI Avantgarde 2001 Sedan AMG rims and skirts
So I guess you don't have the speed limit function on the cruise?
If you press the cruise a light goes on and instead of using it as cruise you get a speed limit function.
Mark
Old Jul 20, 2002 | 05:04 PM
preyx's Avatar
'02 C230K Coupe
Mark
That sounds like an interesting feature, I'd use it to set the max speed so I don't have to stare at the speedometer, but I always believed the cruise control lever just set the minimum speed the car will go at. Are you able to activate the speed limiter just by hitting the cruise lever?
Old Jul 21, 2002 | 01:25 AM
mverboom's Avatar
Yes. I just press the leaver (same way as you spray the windows). Then the light comes on and you can limit the maximum speed.
Is this feature available on the US versions or is it an european feature?
Mark
Old Jul 21, 2002 | 02:07 AM
vadim's Avatar
'19 GLC 300, '19 TM3SR+
Mark
In the US (and I've always thought - everywhere else) it doesn't limit the maximum speed - it maintains a constant speed. It you then press the gas pedal, it makes the car go faster, but when you release it, it returns to the set speed. In this sense, it limits the minimum speed. If you touch the brake pedal, it disengages.
Old Jul 21, 2002 | 03:16 AM
mverboom's Avatar
Ok, I'll add a picture of my cruise. Do you have the same one in your car? Including the light?
Mark
Old Jul 21, 2002 | 04:26 AM
  #32
Lynn's Avatar
We do not have the light. On the surface where you have a light, we have an arrow pointing upwards labled "ACCEL. SET", and one pointing down labled "DECEL. SET". On the top surface is an arrow point forward labeled "OFF" and on pointing to the rear labeled "RESUME".
Old Jul 21, 2002 | 05:43 AM
  #33
mverboom's Avatar
Ok, that explains a lot. Weird that mercedes doesn't provide this feature in the US...
Mark
Old Jul 21, 2002 | 10:12 PM
  #34
PoonerElRay's Avatar
2017 GLA 250 4Matic
Hey, the European tachometer looks different from the North American version. Your redline begins at 5000 rpm whereas our's start at 6000 rpm
Old Jul 21, 2002 | 11:42 PM
  #35
Lynn's Avatar
I think his car is a Diesel, which has a lower redline.
Old Jul 22, 2002 | 04:23 AM
  #36
mverboom's Avatar
Eh, it's a diesel, it doesn't rev that high
Mark
Old Jul 23, 2002 | 01:17 AM
  #37
staticwd's Avatar
what?
what?
which other cars have this besides the bimmers and the MB's?
