HELP! 02 C240 Problems, Car Stops Responding!!
), the car would coast at 2 mph on idle, it felt like it was misfiring, maybe like 3 cyls working. If you turn the car off and Start it, it would have a hard time starting it cranks for like 5 seconds, and fires up and if you put it into drive it will coast a little bit but accelerator wont do anything, it showed and Electrical sign and shut off. If you wait 10 minutes and start the car it drives fine and then the same thing happens, so i disconnected the battery for 10 mins and reconnected it, it drove like its brand new, hasn't done anything sense, but i have taken it down to mercedes to have checked, would anyone happen to have an idea on what it is????? I Love the car but don't want it to give me problems
if the problem is the alternator and the recall finally arrives to the c-class owners, even though the warranty of the car maybe up, you will still get a new alternator without any charges. so i suggest changing something else (or everything)
), the car would coast at 2 mph on idle, it felt like it was misfiring, maybe like 3 cyls working. If you turn the car off and Start it, it would have a hard time starting it cranks for like 5 seconds, and fires up and if you put it into drive it will coast a little bit but accelerator wont do anything, it showed and Electrical sign and shut off. If you wait 10 minutes and start the car it drives fine and then the same thing happens, so i disconnected the battery for 10 mins and reconnected it, it drove like its brand new, hasn't done anything sense, but i have taken it down to mercedes to have checked, would anyone happen to have an idea on what it is????? I Love the car but don't want it to give me problemsTrending Topics
i don't get why you didn't bring it in to the dealership when this happened or call the road side assistance. all the information should've been in your owner's manual. if the Error code is lost when you disconnected the battery good luck on getting the problem fixed some dealership tech don't look at stuff other than what's on the star-diagnostic.
in the driver side sunvisor mirror.......
you'll see a number there to call!
here i'll give you the number
Good luck with everything!
My car is out of warranty. How much would it be for them to tow my car?
