Exactly what is the Rim bolt pattern and offset?
HRE 441
19" x 8.5" FRONT
19" x 9.5" REAR
5 on 112 bolt pattern
40mm offset
or do I have to go with a 35mm offset?
HRE 441
19" x 8.5" FRONT
19" x 9.5" REAR
40mm offset
Front offset on w203 is 32
Rear offset on w203 is 36
The bolt pattern is dead on for the w203, but the not sure how well the 40mm offset will work. Also, how is the offset 40mm for both front and rear when they are different widths (8.5 vs. 9.5)?
judging from the offset, no that set will not clear your from brake or rear for that matter. For the front you need at least ET35-32 depending on the style of the wheels. For the rear it should be at least ET38-35.
