Burn out??
Old Nov 26, 2005 | 04:44 PM
KIRA's Avatar
2002 C230 coupe , NOt THE AVATAR!!
Burn out??
i found this picture while i was searching for benz, and i found this picture really cool and i wonder if C could do it too...
Old Nov 26, 2005 | 05:19 PM
SEXSPHERE's Avatar
//WALD C320 Magnifique [sold], BMW Z4 3.0i 6spd[sold]
We could but we dont want 2
Old Nov 26, 2005 | 05:23 PM
rrpnow's Avatar
2006 C230 SS
you can... turn your car on dynomode... search under my threads... i made a post about it... the link is in there too
Old Nov 26, 2005 | 06:22 PM
r3v1ls's Avatar
C 230K Coupé
Yes it's possible, much much easier with a 6speed manual. I can prob hold my burnout till my tires are gone. Press the ESP OFF button, hold the break, rev the engine up. Then release the break pedal until only a little bit of it is being applied.
Old Nov 26, 2005 | 06:43 PM
white_w203's Avatar
is SOLD
19-inch tires is a lot of money.
Old Nov 26, 2005 | 06:51 PM
clkcadet's Avatar
S550
lol its tough to do in these cars theres too much nanny action involved.... maybe im doing something wrong but the standard "turn esp off then brake and hit gas" method gets nothing for me maybe ill get a half second of wheel spin then the revs drop and the esp light flashes
Old Nov 26, 2005 | 08:10 PM
r3v1ls's Avatar
C 230K Coupé
Dyno Mode might actually help you out with that. Doing it with an automatic is a lot harder especially when these cars don't have that much power...
Old Nov 26, 2005 | 09:21 PM
advans's Avatar
C55 ///AMG, 535xi
lol i agree, I saw a pic of a S class with a burnout
Old Nov 26, 2005 | 10:41 PM
pookie's Avatar
2013 c300 4matic, 2002 c240
i do it when threads are gone, right before i'm getting new tires. the tires are going to get disposed of anyway so might as well have some fun before you put the new shoes on (note: this type of fun could ruin your transmission and have an annoying 'check engine' light on till a service tech takes it off)
Old Nov 27, 2005 | 12:47 AM
Cappa26's Avatar
A box on 4 wheels
RRPNow can you post the forum link here , cant seem to find it
Old Nov 27, 2005 | 12:09 PM
rrpnow's Avatar
2006 C230 SS
How To Disable Safety Feature
Old Nov 28, 2005 | 02:34 AM
rtking's Avatar
2002 C230 Coupe
Actually quite easy to do with the automatic... but I have the 2002 C230 Coupe with the 2.3, so maybe that makes a difference? I can easily smoke the rear tires by torque-braking the car and ESP switched off. Use your left foot to hold the brake (not too hard, just enough to keep the car from rolling forward) and use the right foot to apply throttle. I've got 225/45-17 BF Goodrich G-Force Sports (pretty sticky) and they smoke up very well. This isn't something I do often... just when I'm having a bad day at the office and want to vent some frustration in the company parking lot.
Bob
Old Nov 28, 2005 | 04:48 PM
gaiex's Avatar
'13 E500 Coupe AMG// '17 E350d // '24 E53 AMG
I can do it too with my CDI
Old Nov 28, 2005 | 05:24 PM
clkcadet's Avatar
S550
Bob
must be something wrong with my car hehe i cant do it with my 3.2 engine..... maybe im hitting the brake too hard? but then the car will lurch forward
Old Jun 27, 2006 | 06:11 PM
chase720's Avatar
2002 C320
Its kind of easy. Hold the brake and gas with ESP off. Tire spin and lots of smoke. Dry it should hold through first and wet I have gotten into third with tires still going.
Old Jun 27, 2006 | 06:30 PM
06C230's Avatar
2006 C230
make sure you put bleach under your rear tires first. If you didn't that might be the problem.
Old Jun 27, 2006 | 10:44 PM
Tangerine's Avatar
Is @ Home
my car is not an automatic but i was wondering if it was possible to do neutral drop in the c.
Old Jun 28, 2006 | 12:02 AM
patrick_y's Avatar
2006 E55 and 2002 E320
You can do it with your 3.2. I've seen someone else on the forums with a 270? that span out his tires quite brutally.
Still, I wouldn't want to do it, lots of wear and tear on the drive train plus it's expensive on the tires.
Old Jun 28, 2006 | 10:11 AM
Trekman's Avatar
Silver 2002 C32, Silver 2006 CLK 350
yes you can do it on a C class but you have to get a C32 or a C55 to get a real good burnout
I woundnt do a neutral drop on a automatic you will need a new tranny if you do it after 3 or 4 times i would do brake torque
Old Jun 28, 2006 | 09:42 PM
blkc230k's Avatar
2005 Obsidian Black C230 Komp Sports Sedan, 2006 Iridium Silver ML350 SUV
look what i have found!
Old Jun 28, 2006 | 11:55 PM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
burn-out is for the rich. i rather save my tires.
Old Jun 29, 2006 | 02:10 AM
StillKickin's Avatar
Mine 2005 C230 Kompressor, Dad's 2005 ML350
Ive done burn outs before on my 05 c230....just gotta put it in dyno-mode hold down the brake enough to not move and get on the gas....you cant neutral drop on the C or the M with an automatic tranny...I tried...it waits till the revs go down then gets in gear.
Old Jun 29, 2006 | 01:51 PM
Sauceboy01's Avatar
Blimp
And unfortunately Dyno Mode or not, the manual has a 4k RPM limit so you can rev it up past that unless you're going about 3-5 mph...
