Retrofit US COMAND
TIA.
He sells completely OEM kits?
Also, isn't switching CD's a pain? The navigation unit is in the trunk, right?
Euro spec units have a TV button; 2003 US spec comands have a blank button; 2004 US spec comands have a SAT button, and will integrate with a SAT radio kit as soon as this is installed in the car as well.
If you have a pre 2004 W203, it won't be pre-wired for SAT, but we can get you a wiring loom for that as well. Depending on where you are located, we may even be able to install the entire SAT kit along with a 2004 US unit.
All 3 comand units will work with a TV tuner (which we don't have in stock, unfortunately). The US units need to be versioncoded through Stardiagnose in order to work with TV.
The 2004 US unit can NOT get both SAT and TV, as the SAT button will be used for TV if that is the way you want to go...
greetingz,
BigSis
