HID Lights
If that is true then there shouldn't be any problem with you asking your dealer to install it. (That's what I would do if I didn't feel comfortable installing it myself.) Keep in mind that a dealer has a right to refuse to install anything they didn't sell.
I have installed factory xenon headlights into a BMW and an Audi, and it wasn't too dificult but it took a few hours to do it right. If you think you can do it then give it a shot but if not then have your dealer do it.
i was told that even if self-leveling, oem, etc., installing HIDs are illegal. basically, they have to be installed at the factory (not the dealership). hence, a lot of aftermarket HIDs have the "only for offroad use" disclaimer.
autoclass.net told me that they would be receiving HIDs for the C230k late this month for about $800 each.
I talked to my service advisor and he did not recomend installing an aftermarket HIDs. There seems to be a problem with the watege that si being pulled by the standard light bulb (55w or so) and HID only pulls about 20w-25w so the omputer thinks that the light is out, and there might be a problem.
Also, I don't believe that self-leveling is required in the states... only in Europe. My motorcycle has a non-self-leveling xenon headlight which is DOT legal.
in fact, the police need a specific little light gauge to determine if your hids are illegal, and very rarely do they have em in their cruisers.
"sir, do you know your HIDS are too bright"
"no officer i didnt, they came with the car, so i assumed they were fine"
if that doesnt work, pretend your on the way to the hospital cause your wife is having a baby
greg
i know most every non factory installed hid is not street legal, but really how many times are you gonna get pulled over for your hids???
greg
the computer senses a burnt filament by the resistance of the curcuit, not the wattage. I'd say there's a 99.9% chance that the computer wouldn't think the bulb is blown. Although the resistance of the HID ballasts would be different from just a bulb, even if you had a problem the worst that would happen is you get the little indicator light telling you a bulb is out and even then you could bypass this by using a simple resistor from radio shack.
Re: resistor from Radio Shack - BAD IDEA. Typically, an HID system wattage is in the 30-50 watts range, whereas stock H7 rates at 55W. If you want to install a parallel bypass resistor, it MUST be capable of dissipating a whooping 10-20W (of heat)! Have you ever seen resistors of this wattage? All this heat would stay UNDER the hood, too!
My cousin and I got pulled over in London for driving with the fog lights on in his SLK, but that was London.
Here in No. VA they use fog lights all the time, especially SUVs (hate them!)... Not a single case I'm aware of...
