Engine oil
Old Dec 17, 2005 | 01:20 PM
jasonlaa's Avatar
Engine oil
do u guys know how many bottles or how much of engine oil i need to do any oil change for a 2001 C240? cause i m living in a small town, and no shops have any parts, they want me to buy the engine oil myself...
thanks
Old Dec 18, 2005 | 11:54 AM
Bing's Avatar
C320 Sport Sedan 4MATIC, Cayenne S, Bayliner Capri V8, Subaru STi
hmmmm.....AMSOIL not listed in manual
but it's listed in their site:
APPLICATION
AMSOIL Synthetic 5W-40 European Motor Oil is recommended for applications specifying the following:
API SL, CI-4, CF
ACEA A3/B3
BMW LL-01/98
Daimler Chrysler 229.3, 229.1
Opel Long Life Service Fill GM-LL-A-025
Opel Diesel Service ill GM-LL-B-025
Porsche
Volvo
Saab
Volkswagen 501.01, 502.00, 505.00
AMSOIL Synthetic 5W-40 European Motor Oil surpasses the most demanding European oil specifications. It is recommended for European gasoline and diesel vehicles, including but not limited to, Saab, Audi, Volkswagen, Mercedes-Benz, Volvo, Land Rover, Opel, Mini Cooper, BMW, Peugeot and Porsche.
Link
I want this oil....can I use it?
Old Dec 18, 2005 | 02:16 PM
jasonlaa's Avatar
Thanks Sooooooooooooooooooo Much...
But when i buy it, do i just buy 7.5L and the oil filter then i will be all set?
what that rare axle?
Old Dec 19, 2005 | 05:00 PM
X72's Avatar
X72
Honda Accord
Bing, I have no personal experience with Amsoil and do not sell their products so I have no vested interest. I have been using Mobil1 0W-40 because it had been available at a local Wal-Mart for about $4.50 a quart when I stocked up on it. The prices have risen quite a bit since then.
Of course you can use Amsoil 5W-40; it meets MB 229.5 which is their latest spec.
See this list which has often been quoted.
http://www.whnet.com/4x4/oil.html
jasonla, you can use any oil that meets MB 229.3 or 229.5. Buy yourself an extra quart so you will have top off oil in case you need it.
You could check with Wal-Mart, Autozone, Pepboys to see if they will order Mobil 1 0W-40, Castrol Syntec 0W-30 ( the German ACEA A3 oil, not the American version of Syntec 0W-30), or the Belgian Castrol Syntec 5W-40 for you.
But since you are going to have to order your filters, see what is available.
I have seen pretty good filter prices here www.allgermanparts.com
Feeling French? You could order up Elf oil that meets 229.3 available here.
http://cgi.ebay.com/ebaymotors/ELF-O...temZ8022926564
If you look online, I am sure you can find a Motul supplier.
You could take your lack of local supply as an opportunity to indulge in boutique oils if you have the money to spend.
Alternatively, if you don't have the money to spend, you could use a bone stock conventional SM oil in the correct grade for your climate and just do 6 month 5k mile oil changes. No, it won't meet MB's higher specs, but I believe that the higher spec ACEA A3 oils are for conditions that are not replicated in the US outside of running the car on a race track (i.e. running the car flat out on the autbahn for hours). If you change the oil every 6 months, you don't have to meet the MB long life specs. You could then run a used oil analysis just to be sure everything is ok; I use Blackstone Labs.
If you want to learn more about motor oil, do a Google search for the term BITOG.
William
2003 E320
Old Dec 19, 2005 | 06:13 PM
Bing's Avatar
i got free oil change until the year 2010
this site is very informative:
AMSOIL is there:
MB sheet 229.5 approved oils; "MB Longlife Service Oils"
for passenger cars with gas and diesel engines with extended drain intervals beyond 229.3 oils, to 30,000 km, min 1.8% fuel saving, first oils introduced summer 2002. For gas engines of the M100 series, gas engines of the M200 series and diesel engines of the OM600 series (not models with Euro 4 diesel particle filters).
229.5 engine oils must be used with fleece oil filter designed for use with 229.5 engine oils.
AGIP Formula LL DC 5W-30 (I)
Amsoil Synthetic 5W-40 European Engine Oil (USA)
Aral SuperTronic G 5W-30 (D)
Aral SuperTronic M 5W-30 (D)
AMSOIL History http://www.amsoil.com/company.aspx
First to develop an API-rated 100 percent synthetic motor oil.
First to introduce the concept of "extended drain intervals" with a recommended 25,000-mile/1-year drain interval.
First U.S. company to utilize the NOACK volatility test as a standard of performance excellence.
First to produce synthetic motor oils for diesel engines, racing engines, turbo and marine engines.
First to introduce synthetic oils that legitimately contribute to improving fuel efficiency.
First to manufacture synthetic gear lube for automotive use.
First to manufacture a 100:1 pre-mix synthetic 2-cycle oil.
First to manufacture a synthetic automatic transmission fluid for automotive use.
In short AMSOIL was the pioneer , product research and development of synthetic oil then every major oil company made them too.
I've been using AMSOIL in my boat and older german cars and very satisfied with it from cold starts. Mobil gave me hard starting.
thanks
Old Dec 19, 2005 | 09:59 PM
X72's Avatar
X72
Honda Accord
If you are getting the free oil changes at the dealership following the FSS, just make sure they use M1 0W-40 which is what they are typically using anyways. If anything, the knock on this particular M1 is that it really is a 0W-35 oil and that it is a bit thin. The pour point for this M1 is really low. You won't be having any cold start problems related to the use of M1 0W-40. For the extended drains, it shears down to a 30W oil and then gradually starts thickening up; at least that is what it is supposed to do.
Old Dec 19, 2005 | 11:53 PM
jasonlaa's Avatar
Thanks very much, i realli appreciate that
Old Dec 20, 2005 | 06:51 AM
jasonlaa's Avatar
How can i find out whether it meet MB 229.3 - 229.5 though?
sorry to ask a dumb question
Old Dec 20, 2005 | 08:22 AM
X72's Avatar
X72
Honda Accord
Not a dumb question. The oil container usually lists all of the specs it meets. If they jump throught the hoops to meet VW/MB/BMW/GM long life specs, they are usually proud to advertise that fact.
This link leads to a nice review of an oil change on an E320 W210.
http://www.mbnz.org/gallery/showlink...20Oil%20Change
The first picture shows the back of a Mobil 1 container stating it meets 229.5
If you are handy at all, with a couple of ramps and some tools you can do your own oil change. You could also get one of the suction devices and do an oil change completely from the top of the car.
William
2003 E320
Old Dec 22, 2005 | 11:45 PM
jasonlaa's Avatar
thank you thank you
how about transmittion oil? should i bring it back to mercedes dealer or buy my own parts and let jiffy lude or goodyear those places to change for me?
Old Dec 23, 2005 | 02:00 AM
Bode's Avatar
'06 E350, appearance/entertainment/ sunroof/DVD NAV/brilliant silver (C744)/Ash leather
MB Dealer in the US selling the Mobil Oil Mobil 1 0W-40, European Car Formula
Have a look, this is the full synthetic stuff they put in the factory and for a reasonable price per bottle.
http://store.yahoo.com/parkplacemoto...1trismoto.html
Last edited by Bode; Dec 23, 2005 at 02:01 AM. Reason: trying to make the link work automatic.......
Old Feb 12, 2006 | 10:10 PM
a320ca's Avatar
Amsoil
Yes Mobil1 is good but...
"AMSOIL European Car Formula 5W-40, engineered with advanced AMSOIL synthetic technology, is the ONLY motor oil in North America to be recommended for the latest specifications of all three major European automakers – Volkswagen (Audi), BMW and Mercedes-Benz, as well as the latest North American API specification."
I have been a very satisfied AMSOIL consumer for years.
Old Feb 12, 2006 | 11:44 PM
SUNILP's Avatar
2015 E250D
I have been a AMSOIL user for several years. AWESOME oil. Their synthetic tranny fluid makes your gears shift like they're on butter.
Old Feb 13, 2006 | 04:55 AM
pookie's Avatar
2013 c300 4matic, 2002 c240
this guy's posts are only about oil in different forums, bring up 'old' threads and only joined yesterday.
yeah, i'm "not' suspicious at all about his love for amsoil.
Old Feb 22, 2006 | 02:52 PM
a320ca's Avatar
Yes, I imagine it does look suspicious. However, I just took delivery of a 2006 C230 (and thus just joined the forum) and was quoting Amsoil's qualifications regarding it's oil for MB. I did not start a "thread" pushing Amsoil (or bash other brands), just replied to threads inquiring about oil. Oh, and one more thing...I don't sell Amsoil.
Old Feb 22, 2006 | 03:41 PM
levelr123g's Avatar
I am an Amsoil dealer, and yes you can use that oil.
