C320 Wagon Issues
The other big concern is the vibrating/rumbling sounds from the rear hatchback or suspension. Sometimes the hatch sounds as though its vibrating. Other times the rear suspension is clunky and makes rumbling sounds.
So far the dealer has been pleasant. I really like this car and want to keep it for a while. Please let me know if any of you have experienced similar problems. Any feedback is appreciated
Thanks,
Alan
The vibration in the rear can be as simple as unbalanced tires, bad CV joints, broken guibo, or a bad rear end. The door can be adjusted against the stops so it does not rattle.
I love both my wagons, too.
Thanks,
Alan
You might want to take a peak under the car...the rear suspension on most every Benz Ive ever driven is well planted and clunky sounds are not the norm. Rumbling could be a bad tire, or damaged spider gears in the rear differential. Good luck.
