CEL error PO410
Old Jan 16, 2006 | 06:05 PM
Jeff C's Avatar
CEL error PO410
Hello,
I am very happy with my 2002 C230k, but the CEL recently came on and the only code found was PO410 "Secondary Air Injection System Malfunction". The car runs fine. From the web it seems that the AIR motor may need to be replaced. Any ideas from the gurus?
Jeff
Old Jan 16, 2006 | 07:56 PM
Buellwinkle's Avatar
Check with the dealer, the emissions warranty should cover this and that warranty runs a lot longer than the factory 4/50 warranty. But if you are the adventerous type, check the entire SAI system including vacuum hoses and such. You are trying to fix something you know little about you may cause yourself more grief.
