supercharger
I was wondering if i can put a supercharger on my c320. If so how would i go about getting it. Or whats another way to get horsepower.
Kleemann dealers closer to you are:
Conversion Techniques Inc.
9845 Bigge Street
Oakland
CA 94603
TEL.: +1.510.639.0911
FAX: +1.510.639.0297
and Canepa Design in Santa Cruz.
If still interested you may want to bug Magnuson, they buy components directly from Eaton and resell them to tuners who put their names on it like HPS (for the E430) and Jackson Racing, TRD, Saleen, McLaren and others. They may be working on something for the C320.
http://www.magnusonproducts.com/
Another biggy in the Mercedes hot rodding game is Mosselman, don't think they do anything now for the C320 but maybe they are working on it. It's a popular motor.
http://www.mosselmanturbo.com
What is your upgrade budget? that is the real question.
Do a search on this topic. Someone else here has a similar wet dream for a S/C on a C240, and there's similar discussion on that topic. You can't just slap a $10K S/C on a stock C320 engine. Compression ratios also need to be adjusted (new pistons and such). That's more $$$.
Properly designed superchargers, such as the Kleemann Supercharger, are designed to be non-invasive on the engine. Other engine upgrades are not required in order to maintain engine reliability and longevity. The Kleemann Supercharger only runs at .5 bar (as many others follow), however it's intercooler is light years ahead of the competition; including AMG. The result of this is a supercharger that does not require a special low-compression engine to work properly and reliable.
Ben
That is only partially true.
Ben
Now just wait a minute MB-Bob!
I always enjoy your posts cause you seem like the voice of reason. We are not just some kids who happen to run into an AMG supercharger and slap it on.
We have several parties such as MB themselves envoled in this project and it will take several months to prefect!
We all know that the blower will definetely have to be under-run.
We are probably going to be boosting at about 7 to 9 lbs.
I was not able to afford a C32 at the time but when you get an opportunity such as an AMG supercharger for almost free and the support of several tuners, wouldn't you do it aswell???
What is the diffrence between high pressure low density air and low pressure high density air and it's effect on engine wear?
How the heck are you going to manage getting high pressure low density air and low pressure high density air? The two aren't independent of each other. They change in proportion to each other, assuming a constant temp... in fact changing the temp is the only way to raise the pressure without changing the density, so are you really asking how temp effects wear?
In the end it's the mass flow that matters anyway, so, what the heck are you asking?
But for most people the $10K it costs for, say, a Kleeman supercharger could be used, along with a trade-in C320, to get a C32.
No matter how you cut it, you won't get your money back on resale unless you go with the stock car (e.g. a C32). But for some people it doesn't matter. The fun part is messin' with the mechanical bits.
P1/T1=P2/T2 with the T in degrees Kelvin(celcius plus 273)
PV=nRT when n is number of moles and R=gas constant (look it up)
However, at the end of the day, Buellwinkle makes the best case when he says:
The problem with adding 10k in upgrades is that when you sell it, many prospective buyers would look at it as a hot rodded Benz and want nothing to do with it. The best you may be able to get is to take the mod off and sell it by itself but the (reverse) labor is expensive {at a time when your enthusiasm for the whole deal has evaporated--my addition}. If you have a C32 the resale value stays with it.
make the car run as it should.
Good luck by installing the AMG compressor, it can end up beeing the most expencive thing you ever did. Go for a kit which works.
is not exactly the truth.
He is living in a box on a field in Holland and the company counts
Villy Mosselmann himself and a guy whics weld the pipes.
A home page is some times " pumping up " companies.
Just getting back to this thread, Class C. As jswedberg says, if you're getting the bulk of the expense gratis, then you can afford to throw in some of your savings on development work. Most of us would not be that lucky. And if you just love tinkering with cars rather than enjoying driving a C32 now, then by all means spend the next several months making the C240 work. I'm sure you will be successful with enough time and money.
I think the fun part for me is tinkering with things, heck the Mods I've done so far I could've gotten a C320 or pay higher montly on a C32.. In any event, it will be successful and I'll be posting pics and dyno info once we finish.
Ok, it's a Friday afternoon, the end of a long week... and maybe that's why this question has my brain smoking.
