Starter Modifications.
Air Filter
Exhaust
Chip
couple questions....is the supercharger's boost electronically controlled or would i have to change pulley's to get more boost? moreso- at what PSI does the engine currently run at in stock form, and what can it be taken up to before any problems occour?
A C230 with an overboost pulley, air filter and exhaust should make ~ 240HP at the crank.
for the former you can go with: filters, exhaust, chip, pulley, springs/suspensions, wheels, and then lastly bodykits.
for the ladder you can go with: wheels, suspension, exhaust, bodykits, chip, and pulley.
happy modding
for my exhaust, i'd be looking into a cat-back system with hiflo cat. converter, as far as upgrading the intake, i'd be interested in either just a green or K&N filter for approx $50, or is there an entire intake assembly available? again- these may be redundant questions, but i'm only asking because i have tried to research this on my own to no avail...maybe i'm not looking in the correct places? help me out, if you feel so obliged..... much appreciated.
one more issue to address- i suppose i'd like to upgrade the ECM/ECU or just install a chip (for example a lot of cars, such as a 90-96 Nissan 300ZX TT have a chip in the ECM/ECU that can be replaced with a performance chip, or for another example a dodge dakota 5.9 can be chipped or had the "ROM Flashed").....furthermore- i'm wondering why this is considered a "heavy mod"? i'm not critisizing here but i always kind of thought that the basic, introductory modifications done to a car should be to let the engine breathe, primarily (intake & exhaust), then attack the stock fuel maps and ignition curve. after that, if you're running out of fuel, you attack that system.
EDIT: as it seems, the advertisement for evosport chips on this page caught my attention, so that question seems to be all but settled, but one last question on the chips subject would be if there are any other companies that make chips or modify the stock ECM/ECU such as evosport/powerchips?
last but not least......one fellow mentioned the stock intercooler getting a bit overburdened.....is there a performance-oriented unit that will fit in the stock location or a front-mount option? along those lines- when does the stock intercooler begin to hold you back? its amazing they bothered to install a intercooler for only 5PSI. my stock Z ran about the same out of the factory, and i raised it to 12.5PSI....and that was non-intercooled.
for now- i'm just looking to make it fast. if i make it all show and stock go (because lets face it, the little things do have some "umph" from the factory!), then it almost fits into the "ricer" catergory.....at least in my eyes. but hey- tuning is in the eye of the driver, wether it is tuning the looks or the performance.
me? i'm performance oriented. i just got out of a 86 Nissan 300ZX Turbo 5 speed, and i kept it all stock on the looks, but raised the HP to around 250.
thanks again.
I totally tricked out my toyota supra before buying my MB...
eibach, tokico, hks, etc... I know where you are coming from.
