thrust arm broken...
i am having problems with my thust arm and bushings in the front of my car.i have done a search but have not found much on how much they cost to replace. Is there any aftermarket parts for this or do people usually replace it with oem ones.
You don't mention if your car is under warranty. I have the StarMark warranty, and i have had thrust arm, bearings, and bushing replaced under warranty.
Ed
also is this something the average person can replace? I'm thinking not but who knows.
do a search for "Control Arm"
or look at the last page of this link
https://mbworld.org/forums/showthrea...ht=control+arm
Otherwise they are < $100 each, and any mechanic can do it for you, find a cheaper one, or DIY. The cost adds up cause you have to do an alignment after, so you might as well replace them all.
$1000 in parts/labour/alignment to return the car to driving like new is a good investment, and the updated bushings are supposed to last much longer than the 60-100K miles people are getting out of them.
How would I go about doing that? Do you have any instructions? Is it at all easy for a novice car guy? I'd rather not pay 600+ to the dealer.
I'm thinking of finding a shop that can do the work cheaper.
How is it a DIY? Impact gun or some muscles will break the bolts free, then change the arms and take it to get an alignment.
Any mechanic should beable to do these things, its not rocket science cause its a Benz.
Early Signs are a leaking bushing as they are filled with liquid
Late signs are a Clunking when stopping /starting
They are a Common Item with the W203s
She got the alignment, but I am going to do the replacement and then we will get another alignment. Heck, I can swap them out and get two alignments and still come out cheaper.
So, with that said, we have noticed no ill effects but I am all for changing out every bushing I can. What should I change out while I am under there?
Btw, they quoted $409 to fix them (how many?).
UPDATE: I just found a post that shows I had them replaced under warranty at 75,000 miles. This forum is so handy.
Man, they don't last long.
We hit 134,818 miles today. Almost like clock work.Can someone point out the location of the bushing in this photo? I have no idea where it is on each front wheel.
I need someone to post a picture showing me where these bushings are. Once that is done, I am going to order them and do a install guide to replacing the bushings.
Mr. E, can you help a brother out? Tell me where to take a picture and I will take a few shots so we can figure out where it is.
Did that make any sense?
E
http://www.detali.ru/cat/oem_mb2.asp...SGR=030&SGN=01
Look for part #90. Bushing is in the back.
In any case this is for my car. Go to the front page of this and find your car, then look for steering knuckle and control arm diagram.
E
E
I ordered the parts through my friend at a local dealer so I will know a cost on them by Friday, I hope. Probably around $40 each but we will see.
Also, how do you tell they are bad? I am not sure. We have experienced no noises and no fluid leaks. Kinda makes me wonder. We were told by the dealer when they were doing the alignment that they were bad. So I am going off their reccomendation but doing the swap myself (yes, I am going to do a DIY guide
with less fanfare than the transmission pan drop I hope). I will be back with more news as it develops.
beers it takes and at what point is the best for consuming.
You know the importain stuff!Did you get your Mercedes disc? I was looking and all you have is two lower arms and a shock strut. The two arms look like $165 for one and $59 for the other through OEM parts. Not much can wear out or break in the front. I would think a little strut side play would be the first thing that would cause looseness or noise?? Mybe these arms are just crap, my 88 is still on the originals at 320,000 miles.
). Besides always having a problem getting it to load, it thinks I am using a back up copy for some reason, I could not really find anything to do with the thrust bushing or arm on the DVD. Of course, that DVD is a little hard to navigate but I did use the search. When the wife gets home, the car goes up on the lift tonight for some pictures so we can nail down just wth is the thrust arm bushing they say is bad.I called and ordered the bushings today along with a new cabin filter (the one above the battery).
My sliding bridge jack for my lift is not scheduled to get here for another 2 week so I can't do this on my lift until then. However, it would help to actually know what bushing I am looking for and wth is what under there. Maybe we can all hold hands and identify the parts and I can get a nice labeled photo up for all to use.
Update: I just got a call and my parts will be here tomorrow in my hands.
I don't know the price but I order through another dealer so I get a discount on the MB parts because they rip off the average joe that walks in. I get cost +10% at my GM dealer so we will see what the difference in price is. I will call MB and get a price and see what they tell me over the phone.
https://mbworld.org/forums/mercedes-tech-talk/95117-what-s-should-i-worry.html
