Check Engine Light.. Suggestions?
Old Mar 31, 2006 | 06:25 PM
famoussd's Avatar
2002 C230K
I got gas at one of those Chevrons where all 3 octanes come out of the same hose on sunday. Well, today, I go to drive to subway and it started up with a rough idle.. and I get that damn Check Engine Light. I stop the car, then start it back up.. engine runs fine but the light is still there. I did the basic troubleshooting with the fuel cap.. so my thought is to drive the car until the I have no gas in it then go fill it up at a regular Chevron station.. Think that'll make the "Check Engine Light" go away??
Note: My regular warranty is up but I'm still in the extended warranty period. Thanks..
Old Mar 31, 2006 | 06:58 PM
RobertG's Avatar
things with and without wheels
Go to Atuo Zone and have your trouble codes read and then use the search to get further help.
Old Mar 31, 2006 | 07:08 PM
mleskovar's Avatar
'17 Jaguar XF
Originally Posted by famoussd
I got gas at one of those Chevrons where all 3 octanes come out of the same hose on sunday. .
Don't believe using even the lowest octane available would give you a CEL because the engine adapts to octane. You may have corrected the problem when you checked the fuel cap and it takes a couple driving periods for the light to go away. Did you look at the rubber seal on the cap and the end of the filler pipe? Warranty is a good thing. Let us know.
Old Mar 31, 2006 | 07:31 PM
famoussd's Avatar
2002 C230K
Yes, everything checked out ok.. I'll go to AutoZone and see if I get any codes.. Is there anywhere online where I can decipher the number codes?
Old Mar 31, 2006 | 08:40 PM
RobertG's Avatar
when they plug a code reader into your car it will tell you what the code # is and what it means after that comeback here and doasearch or ask a question
Old Mar 31, 2006 | 09:02 PM
famoussd's Avatar
2002 C230K
Ok thanks Robert.. I got another dumb question.. Where are you suppose to plug the OBD 2 Scanner into? I read somewhere that it's located in the passenger area but when I unscrewed the plastic piece (right below the glove compartment), I don't see anything.
Old Mar 31, 2006 | 09:09 PM
famoussd's Avatar
2002 C230K
Oh yeah.. let me add that I just washed my car yesterday.. you think that would have contributed to this as well?
Old Mar 31, 2006 | 11:35 PM
mleskovar's Avatar
'17 Jaguar XF
Where are you suppose to plug the OBD 2 Scanner into? .
Under the dash to the left of the steering column. There's a cover over the connector.
Old Apr 1, 2006 | 12:03 PM
famoussd's Avatar
2002 C230K
Sweet!! Thanks..
Old Apr 2, 2006 | 07:58 PM
famoussd's Avatar
2002 C230K
Ok so I took my car to AutoZone and borrowed their OBD2 Scanner. Hooked it up to my car and got "P0302 - Cylinder 2 Misfire Detected". I went ahead and cleared it since the car was running fine.. and I figured if it really was a problem then it would come up again... I would contribute the misfire/rough idle that I experienced on friday to not starting my car in a few days... Thanks everyone for your help.. If not for this forum.. I would've probably went to the stealer and get bent over..
Old Apr 2, 2006 | 08:04 PM
RobertG's Avatar
[ Thanks everyone for your help.. If not for this forum.. I would've probably went to the stealer and get bent over..[/QUOTE]
Old Apr 2, 2006 | 08:09 PM
bhappy's Avatar
Glad you fixed the prob w/o have to pay more to stealership. Pls keep us update if you found something in the next couple weeks. Hope not though
Old Apr 3, 2006 | 05:44 PM
SteveAustin's Avatar
2005 C230 Kompressor Sport Sedan
Check this out...I had the same exact thing. A few starts and the engine light will clear, but it kept coming back on, most often when going on to the freeway. I waited for another tank of gas and then I had had enough. Took it in to have the dealer look at it / replace the driver's airbag due to recall. It was a bad spark plug, so if I were you, I would take it in if it keeps misfiring.
