service time
Old Apr 5, 2006 | 05:30 PM
Benzino's Avatar
03 c230
service time
my service light just popped up and it says "service B" what does this consist of? should i take my car to the dealership or anyone that specializes in benzes. My warranty is up how much should i expect to pay?
Old Apr 5, 2006 | 05:41 PM
rrpnow's Avatar
2006 C230 SS
read the manual... serach the forum... those will be the responses you will get... but do it anyways, so much easier...
Old Apr 5, 2006 | 06:06 PM
mleskovar's Avatar
'17 Jaguar XF
Brake fluid gets replaced after 2 years but all the other stuff other than change oil or air filters is not worth 'B' service prices at dealer. Look in the book and it will tell you...then do the visual stuff yourself....and pay an indy mechanic to change oil/brake fluid/windshield washer blades etc. if they need it.
Old Apr 5, 2006 | 08:59 PM
Alan B's Avatar
2002 C320 Wagon
B Service
The B service seems to be an overpriced suped-up oil change, with replacement of the two air filters, both cabin air filters (the paper element one under the hood as well as the activated charcoal one under the dash - this seems to be consistent for the C class W203), wiper blade inserts and tire rotation.
I spent about $155 from Autohaus for the air filters, cabin filters and wiper inserts. A local dealer service tech indicated the B service would run about $450. This same tech said the oil change/filter replacement and topping of the fluids would be about $125 - $150.
As far as doing the above work yourself, this is my first MB and the difficulty level was not as bad as anticipated. These service items are not rocket science, you will do just fine. When in doubt ask members questions as many have pictures and service bulletins they will gladly share.
Best of luck,
Al
Old Apr 5, 2006 | 10:18 PM
pookie's Avatar
2013 c300 4matic, 2002 c240
also, if you do-it-yourself, you would not only learn something about your benz, but actually then appreciate and take care of your car more.
