Wetterauer chip mod
Old Aug 13, 2002 | 03:35 AM
hudkang3's Avatar
C230K Brilliant Silver with C2, C7 and Bose system with 6-Disc Changer
Question Wetterauer chip mod
HI, guys
Has anybody done chip mod with a company name called Wetterauer ?
They claims below result.
If you had done it, did you really get this much HP & Torque?
Below information is from this address http://www.chip-tuning.com/usa/main/mainmenu.html.
Mercedes C230 Kompressor 4-cylinder engine in line front engined electronic injection catalytic converter
modification stock tuned
displacement 2295 cc
compression ratio 8.8:1
peak engine HP 193 HP To 230 HP
peak engine torque 206 ft/lbs To 236 ft/lbs
Old Aug 13, 2002 | 03:42 AM
wants a cCoupe's Avatar
yes, they're a pretty good chip tunning company but I belive that is with their pulley + chip and filter too inorder for that gain
Old Aug 13, 2002 | 03:50 AM
hudkang3's Avatar
wants a cCoupe Do you know for a fact?
Yo,wants a cCoupe
Have you check their price with their web site?
Are you saying that the price include their pulley + chip and filter?
Because I already order ITG filter and planning to order ASP Pulley tomorrow.
Guess I need to call them to verify what the price actually includes.
Old Aug 13, 2002 | 03:58 AM
no, I do not know it as a fact but some of there kits comes with a intake fillter and last I read some were that they come with there own pulley for there kit to make that much power. U may want to call them 1st tomorrow before u order anything else.
Old Aug 13, 2002 | 10:05 AM
Buellwinkle's Avatar
I spoke to them about a year ago, they were one of the first to have a pulley for the coupe. They even sent me installation instructions. They don't have a chip for the coupe. It's a pulley, intake, fuel pump mods (for the a/f ratio). It costs $1,299 but there was a MBWorld discount of $100. I've only heard of one being installed and they had a S/C leak afterwards but I can't imagine it being a specific problem to Wetteraur.
Old Aug 13, 2002 | 10:19 AM
renncpe's Avatar
w203 c230K 2002
That has to be a big job to change the fuel pump it in the fuel tank. I hope that Linn's fix for the A/F works in the long run he has a diffrent ecu. The sim 4 unit that is on the C230k will change the cycle time of the injectors (if the fuel pressure is incressed) if it is running rich when compaired to the programing of the ecu. It is a very smart box. I'm currently getting 13.2 A/F at red line with the new ecu. Were going to test several more times over the next few weeks. I'm going to have the adaptive values downloaded tomorrow I want to see if it's trying to change back.
Old Aug 14, 2002 | 01:57 AM
sweet, please keep up updated on the ECU.
also, if one was getting the asp pulley then will the fuel pump fix the a/f problem?
how much money is one looking at for a larger fuel bump ?
Old Aug 14, 2002 | 02:03 AM
linh's Avatar
99' SLK 230 & 01' CLK 430
Renncpe,
I just installed the Vaeth 3.8 Bar fuel pressure regulator and has it dyno at Evosport shop. The A/F ratio drop from 15.1:1 to now at 13.7:1. Renncpe, did you measured the A/F ratio before the CAT or after? I measured the A/F ratio both way. Before the CAT is at 13.7:1 and after the CAT is at 14.9:1. I see that there's a different to where you measure the A/F ratio but some mechanic still said that it does not matter whether before or after the CAT. What about you? What do you think, does it matter?
Old Aug 14, 2002 | 02:17 AM
linh : what A/F ration would make it perfect ?
is 13.7:1 good ?
Old Aug 14, 2002 | 02:35 AM
linh's Avatar
What ever your factory A/F ratio are. My factory A/F ratio 13.0:1 bottom end and 12.5:1 top end (redline). Your car might be a little different then mine. So do a dyno before and after. But in tunning regardless what car, you want the A/F ratio from 12.5:1 to 13.0:1 !!!!
Old Aug 14, 2002 | 08:34 AM
renncpe's Avatar
w203 c230K 2002
Originally posted by linh
Renncpe,
For the dyno (local) it was checked at the rear after the cat when the car goes back to renntech they read off the o2 sensors before and after to get more info.
Old Aug 14, 2002 | 06:51 PM
gilbert's Avatar
linh, do you know if there's any special fuel pressure regulator for the new 2.3K EVO111 eingines?? i've tried a FSE regulator from UK for the 97 230K SLK, it gives much better result than Vaeth because FSE's fuel-line pressure increases with higher revs. The new 2.3K EVO111 engine has fuel regulator but it's half-electronically controlled
Old Aug 14, 2002 | 08:21 PM
linh's Avatar
I am not familar with this engine code.
Vaeth FPR do the same. It increased the pressure as boost increase.
How much and how do you get it? Website, please?
